Are you wanting more or less delay?
Is there a way when stop / start is on to change the setting for how car the car infront moves before the engine turns back on?
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
2018 Allspace 162TSI R Line
More or not have ot turn the car automatically back on
Am I right in saying that;
Dynamic Light Assist - Dips beams depending on oncoming traffic.
High Beam Assist - Simply high beams on/off automatically dependent on traffic.
Has anyone successfully implemented Dynamic Light Assist on their MY18/MY19 Tiguan Highline with R pack? Reading back through this thread it seems like there was mixed results with fault codes appearing etc.
Also the MY19 I'm expecting advertises "dynamic cornering lights" in the specification brochure. Is this a different system to dynamic light assist?
Just tired it on my 2018 Allspace Rline and it works awesome. I usually put the gearbox into Sports when turning on the yellow light due to the throttle lag. Also find when the car changes into 3rd you have to add some more throttle to keep the acceleration constant. after the mod the throttle is more responsive.
DLA - turns the lights in the direction of your steering wheel when cornering
HBA - automatically turns on high beam, and dips it (or parts of it) when the camera picks up on coming cars
Yes, this uses either the fog lights or a small light built into the headlights (depends on the model) to light up the side of the car approx 60 degrees off centre as you are cornering. The light comes on less than 30k/hr with indicator on
Thanks iDiesel!
