Page 72 of 118 FirstFirst ... 2262707172737482 ... LastLast
Results 711 to 720 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #711
    Nov 2013
    AUS
    Quote Originally Posted by MikeyT View Post
    Here you go. Not a very good video but you can see that it's masking the bright road signs, on coming cars on the right and it also created a U shape when there are cars in front of me.
    I did not get any beep from on coming cars so I guess it's working well.
    Just tested my car out tonight driving in the hills. Looks like I have simple high beam assist, did not notice any specific masking when following another car. Takes about 2 seconds for the system to activate the high beam compared to if you did it manually. The system is very sensitive to oncoming headlights so immediately deactivates the high beams before I had a chance to reach for the headlight stalk and deactivate the high beam.
    Overall reasonably impressive. Only shortfalls from my short test tonight were the tight hill corners with undulations, when you're going into a dip it doesn't use high beams (as I would manually) to illuminate more of the road as it is about to go up again.
    Wish my car would also have the active shuttering to mask specific elements but to be honest I didn't expect the MY17-18 cars to have the capability at all.
    Cheers for a few of you guys sorting it out, got me to give it another try and finally got it working.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  2. #712
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by veew View Post
    Was going to try installing DLA on mine tomorrow, but it seems like it’s a waste of time.
  3. #713
    Dec 2018
    Largs Bay, Adelaide
    Quote Originally Posted by Hole46 View Post
    It depends on if your car has the specific hardware installed. I would confirm this before writing it off. Dynamic Light Assist is absolutely amazing when you see it in action, but if your headlights are only capable of High Beam assist then it may not be worth while.
  4. #714
    Dec 2018
    Largs Bay, Adelaide
    Have you visually confirmed you don't have the correct headlights? Do you have a camera in the windshield? If yes, then perhaps you need to look at your coding again because if you've got the hardware then coding DLA is possible
  5. #715
    Nov 2013
    AUS
    I see it would be much more useful on long dark country drives where the roads don't have sharp corners and steep undulations one after the other.
    I drove a lot at night on country roads last year, this would've just made it easier to focus on the road ahead.
    Quote Originally Posted by jdstephens View Post
    I'm in no rush but will check it out. What is it supposed to look like?
    Current:
  6. #716
    Oct 2015
    Yes, it would be more obvious- as long as there’s a car in front of you.
    Be aware it turns off the right high beam, once you go over 99kph. Stupid, but it’s meant to make freeway driving better(it doesn’t)
    To make knowing the correct headlights easier, google Tiguan allspace highline and look at the pics. Another giveaway is how your drl’s look.
    The right lights have a u shaped drl wrapped around one of the ‘bulbs’(made from 3 small straight segments) and a top ‘eye brow’ above the whole lot.
  7. #717
    Mar 2017
    Quote Originally Posted by Psych101 View Post
    Do you need or does this work in combination with the steps to activate high beam assist?
    Hi Psych101,
    Don't think it does. You can program this with or without HBA.
  8. #718
    Dec 2018
    AU
    Hi Psych101,
    Cheers for that
  9. #719
    Dec 2018
    Largs Bay, Adelaide
    See page 60 of this thread
  10. #720
    Dec 2017
    Castle Hill, NSW
    Sensitivity of throttle increased and reduced delay between accelerator pedal input and engine response
    Well that's excellent news Psych101! Makes no sense, but excellent anyway so I'll have to get out the ODB11 again.
