Page 70 of 118 FirstFirst ... 2060686970717280 ... LastLast
Results 691 to 700 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #691
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by CjsTiguan View Post
    Hey Gents,
    Lately I’ve done a lot of research and decided to buy my first VW TIguan and collect it on the 22nd of this month. I’ve ordered a Wolfsburg edition and have been reading up on this forum about all the various mods you have all done and there are some pretty cool
    things.
    The main wuestion I have is should I buy the obdeleven or go with the ross tech to get started on this? It seems most obdeleven posts when using the app don’t always work so just wondering which is best to go with? Also with the obdeleven token system, if you run out of tokens is it costly to get more or how do you get them? Open to either option as you guys are the pros.
    background - I have good IT background Incase that sways decision.
    cheers
    Most of the information you need about a comparison can be found at the start of this forum.
    That being said, personally, I’ve got OBD11 as it’s a cheap alternative and is enough for my needs - basic level modifications. You can download the app for free to see if it’s what you need. Credits can be obtained by watching ads through the app should you run out, but you can also just use long coding which doesn’t require any tokens.
    Happy coding!
  2. #692
    Mar 2017
    Quote Originally Posted by Bushpig667 View Post
    I followed the instructions to the end and ran basic settings. On starting the car and turning on the high beam I would still get a DLA fault which I couldn’t clear.
    At the end of page 2 of the coding instructions there is some additional coding for if you continue to get a fault. I entered all of this coding and it cleared the DLA fault but created a new one with turning lights which I also could not clear.
    For my car, activating Byte 11, Bit 2 was causing this issue. Once I deactivated this I could clear the faults and the system worked.
    Hope that helps.
    Hi BushPig667,
    I tried to do this using OBD11 and I'm getting all sorts of errors.
    Do we run the basic setting for both 4B and A5 or just 4B? I'm not sure if I'm doing this right as there is no confirmation, it only say "Basic setting starting". What does Basic setting actually do?
    Do you also need to undo the changes you made to High Beam assist for this to work? Thanks.
  3. #693
    Feb 2019
    Corsica
    Quote Originally Posted by Simonr23 View Post
    Is it possible to re-activate the sunroof ambient lights via vcds/obdeleven?
    My dealer is struggling. They’ve done the recall work(fuses) and when they did what they thought would reenable them(shouldn’t have ever been disabled according to their system...) nothing.
    Cheers for any help.
    Hi, do you have succed with the sunroof light?
    Mine was build in september 2018. I've the LED on it but i don't find the way to activate it. I also do not the icon on the my discover. Some get the icon but still do not have the LED on this f*****g sunroof
    I try to find a solution with VCDS but it seems to impossible
  4. #694
    Oct 2015
    No luck for me yet
    I have found options on obd11, but they did nothing.
  5. #695
    Dec 2018
    Parramatta NSW
    Hi, Is there anyone around the Parramatta NSW area who could assist with disabling having to hit OK on the screen every time I start the car and allow overtaking on the left and other recommendations in exchange for beer etc?
  6. #696
    Jan 2018
    Auckland, NZ
    Quote Originally Posted by MikeyT View Post
    Hi BushPig667,
    Hi Mikey
    Just basic settings for 4B. One of the fault codes should be that you need to run basic settings after you make the other changes.
    I’ll be honest, I don’t know what basic settings actually does. There is no confirmation that it completes.
    I didn’t undo the changes for high beam assist but in hindsight it may have caused some of errors that I saw. Best of luck. For me it was perseverance that got all my faults cleared in the end rather than specific advice I can pass on.
  7. #697
    Mar 2017
    Hi Mikey
    Hi Bushpig667,
    Thanks for your response. I followed the guide and configured all but got an error. Then I did the extra 4B settings and my High Beam just stayed on and wouldn't turn off. I couldn't shut it off unless I turn the power off.
    I reverted all my settings and now I have this "Error: Adaptive Front Lighting (AFS)" error that I can't get rid of.
    Can you send my your 4B long coding of your car so I can compare? Also to make sure I did the right thing performing Basic setting, what are the steps for performing basic setting?
  8. #698
    Feb 2019
    Corsica
    Last question :
    Is there anyone having the SA of HEX17? With my VCDS (old version 18.2) i can't go in adaptation.
    Thank to a tips, i can go to HEX9 but not on HEX17 > adpatation. I think that if i enter the SA code, i will be able to enter in
  9. #699
    Feb 2019
    you can download the latest VCDS from here Ross-Tech: VCDS: Downloads: Current Release and Manual
  10. #700
    Nov 2013
    AUS
    Hi Bushpig667,
    Did you try doing the following?
    Mk2 Tiguan VCDS Tweaks-screen-shot-2019-02-22-6-06-46-pm-png
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
