Page 58 of 118 FirstFirst ... 848565758596068108 ... LastLast
Results 571 to 580 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #571
    Sep 2018
    New Jersey USA
    Quote Originally Posted by wpisdu View Post
    Take it to the service, this is not normal, I personally find the automatic headlights flawless.
    Sent from my iPhone using Tapatalk Pro
    That’s what I’ll do. I was just hoping there was something I could change.
    Paul
  2. #572
    I was having a poke around the other day and pretty sure there’s adaptation settings for these.
    Dec 2018
    Perth
    Quote Originally Posted by NZ_GolfR View Post
    Yes I have done it on mine. It works well (except for the warning you get when you start the car) and yes you can do it with obd11 as that is what I used. Instructions for doing it should be at the start of this post, if you can’t find it let me know and I’ll re-post it.
    If you could repost it with HUD display it would be much appreciated. I couldn't find the instructions here.
    Thanks
  4. #574
    Dec 2018
    Perth
    Does the warning goes away. Do u have to acknowledge the warning?
    Thanks
  5. #575
    Quote Originally Posted by veew View Post
    Hi guys,
    Thought I'd start a thread on any VCDS tweaks people have had success with. I assume most of the ones that work for the Mk7 Golf would also work but will be great to know which ones actually do work! Any screenshots, pictures, videos associated with the tweaks would be great! I'll let you guys know which ones work when I get my car and get around to borrowing/buying a cable!
    These are the ones I'm keen to do on my Tiguan when it arrives:
    1) Deactivation of auto stop/start
    2) Memory retention of seat heater setting
    3) Deactivation of seat belt reminder
    4) Activation of Volkswagen Traffic Message Channel
    5) Driving school mode
    6) Air-conditioning recirculation memory setting
    BTW, courtesy of DV52, here is the
    Mk7 Golf VCDS reference thread: MkVII VCDS Tweak - Reference thread
    He has uploaded a full BCM database, thanks to VWVY for providing his car: Mk2 Tiguan VCDS Tweaks - Page 8
    CONFIRMED working VCDS tweaks:
    Activation of Volkswagen Traffic Message Channel: Mk7 Golf TSI & TDI - Observations and Questions - Page 56
    Deactivation of auto stop/start (courtesy DV52 and VYWY - post #94, exactly the same way as Mk Golf 7)
    CONFIRMED working OBD11 tweaks:
    Some cosmetic changes to AID and central MFD
    (courtesy NZ_GolfR): Mk2 Tiguan VCDS Tweaks - Page 26 & Mk2 Tiguan VCDS Tweaks - Page 10 & Mk2 Tiguan VCDS Tweaks
    More tweaks: LED lights in door mirrors, DRL adjustments, refuel quanity, fan speed indicator when in auto, changing comfort blink amount, guage sweep, beep when locking/unlocking car (cheers bestyjny): Mk2 Tiguan VCDS Tweaks
    Screen nag deactivation (cheers VWVY): Mk2 Tiguan VCDS Tweaks
    Active Lane Guidance intervention settings (cheers Fried_noodles)A guide to enable EU specific features for AU Spec Tiguans
    Light Assist (NZ_GolfR): A guide to enable EU specific features for AU Spec Tiguans
    TMC, DRL option in Head Unit, Auto window closing, Dynamic Road Sign display(Cheers hoola): A guide to enable EU specific features for AU Spec Tiguans
    Easy Entry/Easy Exit seat function (NZ_GolfR):
    http://www.vwwatercooled.com.au/forums/f238/mk2-tiguan-vcds-tweaks-116815-18.html#post1239603
    360* Camera for Discover Media infotainment systems (Hugo_nz): Mk2 Tiguan VCDS Tweaks
    Always on rear brake light DRLs (NZ_GolfR): Mk2 Tiguan VCDS Tweaks
    Air-conditioning recirculation memory setting: Mk2 Tiguan VCDS Tweaks
    3rd rear brake light activation, Door mirror LED on with folding of mirrors, cornering fog light speed sensitivity: Mk2 Tiguan VCDS Tweaks
    Haldex AWD system adjustment: Mk2 Tiguan VCDS Tweaks
    Key Fob works when outside the car even whilst engine running (allows you to get the car running to precondition the interior and walk away with a locked vehicle): Mk2 Tiguan VCDS Tweaks
    Driving School Mode: Mk2 Tiguan VCDS Tweaks
    Deactivate the Prevention of cars overtaking on the Right (Tigger73): Mk2 Tiguan VCDS Tweaks
    - This tweak is helpful on the freeway when you are not in the right lane and approach a slower car driving in the right lane.
    Usually the car slows to the other cars speed (annoying if the car in the right lane travelling at 100km/hr in a 110km/hr zone) and does not proceed past them.
    Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane.
    AutoInstruct's OBD11/VCDS tweaks:
    https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
    Stemei.de coding: https://www.stemei.de/pages/coding/vw-tiguan-ii-ad.php
    Record of NZ_GolfR's tweaks:
    https://oncall-my.sharepoint.com/per...ding%20Changes
    Hi, could you help me? Do you have the process to enable Lane Assist Tiguan Rline 2018? I tried many process but didnt work. I use VCDS genuine. Best regards.
    Enviado de meu SM-G950F usando o Tapatalk
  6. #576
    Dec 2018
    Perth
    Hello,
    I got the obd11 pro and used the apps (credit points) to turn on the traffic recognition sign and reeboted infotainment but its not working. I lost the speed limit on the navigation which i expected but nothing is showing on the info display. I went through it the long coding and check every step to make sure the app made changes and everything was ok except one step in A5 module adapt road sign detection fusionmode wasnt changed to road sign detection, so I changed it manually and reeboted again but still nothing.
    Can anyone help me out or have any ideas?
    Thanks
  7. #577
    Quote Originally Posted by MartoWolfie View Post
    Hello,
    Thanks
    I had the same problem. Until now i dont have solution!! Somebody have a solution?
  8. #578
    Dec 2018
    Perth
    Quote Originally Posted by PapaLeguas View Post
    Now i put everything back but lost the fusion road sign speed limit on the gps. It wont show speed limit on the infotainment gps anymore like it did before the coding.
    I hope you find some solution. I kind of stuck
  9. #579
    Aug 2018
    Vic
    Hello,
    Thanks
    Have you gone into the Vehicle Settings, then Instrument Cluster and turned on ‘Dynamic Road Sign Display’?
    Mine works great. I do get a quick message in the AID that says ‘Dynamic Road Sign Display is currently restricted’. Not sure this is normal or not.
  10. #580
    Dec 2018
    Perth
    Quote Originally Posted by Clarkie View Post
    Yeah I did. It was ticked and then I rebooted infotainment. Did you code it manually or used the app? Which vehicle do you have? I ll give it another go this evening
