Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Sorry guys, I use Taptalk and searching didn't come up. But thank you!
Sent from my SM-G965F using Tapatalk
Hi All, I stumbled across this a while ago tweaking with my OBD11 and felt I would share (apologies if this is a repost).
This will stop the Adaptive Cruise Control from braking/slowing the car when overtaking slower vehicles on the left or right!
Deactivate ACC Braking on Overtaking
- Module 13 (Adaptive Cruise Control)
- Long Coding
- Overtaking_right_prevention
- Select “Deactivated” (Default Active)
Alternatively, Byte 02, Bit 5 (untick)
Hope this helps!![]()
MY18 Tiguan 162TSI R-Line, Black, DAP, Sunroof & Tow with APR Stage 2 Tune & DownPipe
Did you use an app from obd 11 or did your use long coding for this? Do you need front camera also?
Sent from my SM-G9650 using Tapatalk
its in long coding, it’s part of the ACC, if you have the cruise set and your on a dual carriageway on the inside lane and coming up on a car in the right lane then the car slows to the speed of the car in the right lane, the mod stops you slowing allowing undertaking, it was discussed on the Passat/arteon forum a while back
Have a look in the ACC module and see what the overtake right prevention is set at
