Have tried a few of the tweaks here, thanks to all for researching and sharing. Used VCDS to change everything. My thoughts/results:
Traffic Reports/TMC
- Couldn't get it to work. Might have done something wrong in my setup, had a few goes but no results. Used 1024 and another setting I found on OzAudi, both no go so far. Mine is a late 17 build with the newer head unit, so maybe something is different.
Traffic Sign Recognition
- Works well, quite handy. Going to keep it on. A little fiddly to setup though. Don't know why it's not enabled on the Oz delivered cars.
Disable start/stop
- Works! Great
Haldex AWD setting
- Changed to the increased traction setting. Massive difference! Feels like a different car. Now drives something like I want it to, can notice the extra drive from the rear. It reminds me of the Q5 I drove in terms of feel on the road. Will leave it for a while and see what happens, if no noticeable downsides I'm tempted to leave this setting on permanently.
Sent from my SM-G955F using Tapatalk
Only when it can't find a sign in the first few minutes after starting up, goes away after a few seconds. As soon as it sees a speed sign it's all good. Even picked up the random 10km/h sign in the supermarket car park tonight.
Edit: I set it to 'detection' rather than 'fusion'
Anybody available for some coding around Norwest/Kellyville. Looking to get the TMC and sign reading (anything worthwhile too). Case of beer on the cards. Thanks
Messaged you, thanks Champ
Hi all, I had trouble getting any more than 3 flashes of the convenience turn signal... here is the solution:
Performed on OBDeleven
Convenience turn signal:
Central electrics 09
Adaptation
Aussenlicht_Blinker
Komfortblinken Blinkzyklen (value 0-5)
APPLY
(On car centre console) MENU
Vehicle
Settings
Factory settings
Reset individual settings - Light
Back
Light
Convenience turn signal (un-check/check)
Ta Da![]()
Hi,
Is anyone available to carryout some coding around Toowoomba/Brisbane area looking for the start/stop deactivation, start up warning, tmc, auto highbeam and any other worth while codes.
I have a 2017 162tsi.
cheers
