veew: I've just had a look at your post containing the tweak instructions (the table looks familiar - where have I seen the table before?)
As for the rain closing tweak instructions, you are probably aware that this has been one of the more problematic tweaks to get working on previous versions of MQB vehicles. I'm not sure if the normal gremlins for this tweak have been evicted on the latest version of the Tiggy, but I note that your instructions have omitted the required change to the code-string on the RLS/RLFS/RLHS (not sure which is installed in the Tiggy). This module is a slave module to the BCM on these cars - so access is a little different to normal modules.
Here's an extract from my tweak instructions relating to the RLS/RLHS/RLFS module on "MQB" cars:
Auto RainClose - Code-string Changes to RLS/RLFS/RLHS
1. From the Installed tab on the Select Control Module screen, select 09-Cent. Elect.
2. On the Open Controller screen for address 09 - Cent. Elect., click the Coding - 07 tab
3. When the screen below opens, click on the pull-down down tab in the middle of the screen (as shown next to the red arrow). As indicated in the picture, the BCM (Body Control Module) has two "slave" modules, one of which is the RLFS
4, Select RLFS and click on the Long Coding Helper tab.
Note 1: on some vehicles, the slave module will be RLS, or RLHS 5. Select Byte 0 and place a tick in Bit 1 and Bit 2 as shown in the picture below. Exit this screen
6. When the screen below appears, ensure that the New coding box contains the Hexadecimal value 06A8DD Click the Do it! tab. Go back to the open controller screen
Note 2: some forums report "error 31" message at this point. If this error message appears, manually enter 06A8DD into the New coding box instead of using the Long Coding Helper. Then click the Do it! tab Note 3: On some mk7 vehicles, the default coding string for the rain sensor is 01E8DD. If this is the case, the required hexadecimal value in the new coding box is 07E8DD.
Of course I can't guarantee that with these changes, Auto-rainclose will work - but I suspect that the software switches on Byte 0, Bit 1 and Bit 2 are needed even on the Tiggy!
PS: there is also an "in-car" procedure that needs to happen with this tweak as follows:
Auto RainClose - In-Car, setup procedures
Auto RainClose - Factory reset procedure
This tweak requires that the control unit be reset after the coding changes above have been made. This is done using the following steps:
- Press the CAR button on the RH side of the Discover media Unit
- Press the set-up panel on the bottom RH side of the screen
- Select Factory Setting panel (it's the very last entry on the list)
- On the Factory Setting screen, select Reset Mirror and Wiper Settings
- Press the Reset panel
Auto RainClose -Menu enabling procedure
For Auto RainClose to work, the function must first be enabled in the Discover media screen. This is done using the following steps:
- Press the Opening and Closing panel
- Place a tick in the Automatic closing in rain panel as shown in the picture below.
- Make sure that the settings for all other options (especially in Opening and closing) are appropriate and that they have not been changed by the factory reset process above (e.g. check that Convenience opening option isn't set to "off")
- Exit the screen
source - 3askoul/www.Golfmk7.com
Auto RainClose - Test and operating procedure
- Make sure that the wiper stalk is in the rain sensing position (i.e. up one position) and that the headlights are switched to the Auto position
- Wind down one, or more windows, and/or sunroof
- exit and lock the vehicle using the remote fob or KESSY
- Wait a minute, or two and pour water on the rain sensor, or tap the rain sensor with your fingers.
- The open window(s)/sunroof should close
Note 5: a further feature of this tweak is that if the window(s)/sunroof is left open for an extended time (generally overnight) without rain, or intervention, the open aperture(s) will be automatically shut.
These do not work. Do you want to help me?
- Automatic Window Closing in Rain
- Gauge/Needle sweep on AID
Can you describe this feature?
I activated it, I do not see any differences ...
- Enable rear DRLs
- Disabling screen Nag
- 3rd/High-Mounted Brake Light Tweaks
You did not activate. Do you want the instructions?
- Liters needed for refilling fuel
- beep at car closing / opening
- Enables / Disables Daylight Lights
- Infotainment System Skinning
- Infotainment System Logo
- Driving profile
- Comfort Blink Cycle (indicators)
- Emergency lights: abrupt braking, multiple collision, accident
Regards,
New Tiguan 2.0 TDI Executive 150CV DSG - Tungsten Silver - Sebring 7X18 et 43
Ergo Active, Driving Profile Selection, Park Assist (Area View, Rear View, Parl Pilot), Teck Pack (Discovery Media, Signature LED e Dynamic Light Assist), Safety Pack, (Emergency Assist, Traffic Jam Assist, Rear Traffic Alert, Side Assist Plus).
Aftermarket: Sign Assist, Start&Stop off, Day lights, Closing windows with rain, AID oro style, Fuel filling quantity.
Formally know as fmonaldi
Tiguan MK2
In case of sliping, you can activate the "Proactive Occupant Protection":
- Front seat belt pretensioning
- Panoramic roof closure
- Closure of lateral crystals.
Regards,
Tiguan MK2 - 2WD
It can be activated - Assistant descent
Features of 4WD Drive profile Offroad → (Driving Mode Selection)
Regard,
Instructions to set speed?
Hi Guys, anyone know of a way to disable the headlight wash function please?
cheers
Gary
2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
