Page 32 of 118 FirstFirst ... 2230313233344282 ... LastLast
Results 311 to 320 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #311
    Quote Originally Posted by veew View Post
    Just tested my car. Didn't work regardless of whether the car was locked or unlocked.
    My setting in the options menu is ticked permanently as well. Pity
    veew: I've just had a look at your post containing the tweak instructions (the table looks familiar - where have I seen the table before? )
    As for the rain closing tweak instructions, you are probably aware that this has been one of the more problematic tweaks to get working on previous versions of MQB vehicles. I'm not sure if the normal gremlins for this tweak have been evicted on the latest version of the Tiggy, but I note that your instructions have omitted the required change to the code-string on the RLS/RLFS/RLHS (not sure which is installed in the Tiggy). This module is a slave module to the BCM on these cars - so access is a little different to normal modules.
    Here's an extract from my tweak instructions relating to the RLS/RLHS/RLFS module on "MQB" cars:
    Auto RainClose - Code-string Changes to RLS/RLFS/RLHS
    1. From the Installed tab on the Select Control Module screen, select 09-Cent. Elect.
    2. On the Open Controller screen for address 09 - Cent. Elect., click the Coding - 07 tab
    3. When the screen below opens, click on the pull-down down tab in the middle of the screen (as shown next to the red arrow). As indicated in the picture, the BCM (Body Control Module) has two "slave" modules, one of which is the RLFS
    4, Select RLFS and click on the Long Coding Helper tab.
    Note 1: on some vehicles, the slave module will be RLS, or RLHS
    5. Select Byte 0 and place a tick in Bit 1 and Bit 2 as shown in the picture below. Exit this screen
    6. When the screen below appears, ensure that the New coding box contains the Hexadecimal value 06A8DD Click the Do it! tab. Go back to the open controller screen
    Note 2: some forums report "error 31" message at this point. If this error message appears, manually enter 06A8DD into the New coding box instead of using the Long Coding Helper. Then click the Do it! tab
    Note 3: On some mk7 vehicles, the default coding string for the rain sensor is 01E8DD. If this is the case, the required hexadecimal value in the new coding box is 07E8DD.
    Of course I can't guarantee that with these changes, Auto-rainclose will work - but I suspect that the software switches on Byte 0, Bit 1 and Bit 2 are needed even on the Tiggy!
    PS: there is also an "in-car" procedure that needs to happen with this tweak as follows:
    Auto RainClose - In-Car, setup procedures
    Auto RainClose - Factory reset procedure
    This tweak requires that the control unit be reset after the coding changes above have been made. This is done using the following steps:
    1. Press the CAR button on the RH side of the Discover media Unit
    2. Press the set-up panel on the bottom RH side of the screen
    3. Select Factory Setting panel (it's the very last entry on the list)
    4. On the Factory Setting screen, select Reset Mirror and Wiper Settings
    5. Press the Reset panel
    Auto RainClose -Menu enabling procedure
    For Auto RainClose to work, the function must first be enabled in the Discover media screen. This is done using the following steps:
    3. Press the Opening and Closing panel
    4. Place a tick in the Automatic closing in rain panel as shown in the picture below.
    5. Make sure that the settings for all other options (especially in Opening and closing) are appropriate and that they have not been changed by the factory reset process above (e.g. check that Convenience opening option isn't set to "off")
    6. Exit the screen
    source - 3askoul/www.Golfmk7.com
    Auto RainClose - Test and operating procedure
    1. Make sure that the wiper stalk is in the rain sensing position (i.e. up one position) and that the headlights are switched to the Auto position
    2. Wind down one, or more windows, and/or sunroof
    3. exit and lock the vehicle using the remote fob or KESSY
    4. Wait a minute, or two and pour water on the rain sensor, or tap the rain sensor with your fingers.
    5. The open window(s)/sunroof should close
    Note 5: a further feature of this tweak is that if the window(s)/sunroof is left open for an extended time (generally overnight) without rain, or intervention, the open aperture(s) will be automatically shut.
  2. #312
    Nov 2016
    MAPLETON Qld
    Came across these new tweaks on AutoInstruct website:
    Haldex All-Wheel-Drive Adjust Traction
    Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
    Select AWD Control Unit
    Adaptation
    Logic
    Choose from ‘Standard, Increased Traction, Less Noise’
    Closing Windows When Ignition Off
    Allows you to operate all windows after the ignition has been switched off and doors opened.
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    (13) – Zugangskontrolle 2 released trailing FH cancel at Tueroeffnen
    Value = Aktif
    My friend currently has my OBD2 and tablet so won't get a chance to try it anytime soon.
    Tried to apply the window operation when ignition off tweak on my Tiguan but I cannot find this Adaptation in Control unit 09.
  3. #313
    Oct 2017
    Italy
    Just wanted to thank everyone who has contributed to this thread. I've activated the following thanks to many of you:
    - 3rd/High-Mounted Brake Light Tweaks
    - Avoid Dimming LED Lights when Indicating Golf Mk7
    - Traffic sign recognition/Dynamic Road Sign Display
    - Automatic Window Closing in Rain
    - Enable rear DRLs
    - Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
    - Disable Start/Stop
    - TMC Traffic
    - Seat heating memory
    - Enable Fan Speed Indication for Airconditioning when in AUTO mode
    - Gauge/Needle sweep on AID
    - AID GTI/R adaptations
    - AID Colour change
    - Disabling screen Nag
    - LED lights in door mirrors light, even in close
    - Lock Acknowledge with Horn Golf Mk7 instructions
    - ‪Automatic Air Recirculation
    These do not work. Do you want to help me?
    Can you describe this feature?
    I activated it, I do not see any differences ...
    - Enable rear DRLs
    You did not activate. Do you want the instructions?
    - Liters needed for refilling fuel
    - beep at car closing / opening
    - Enables / Disables Daylight Lights
    - Infotainment System Skinning
    - Infotainment System Logo
    - Driving profile
    - Comfort Blink Cycle (indicators)
    - Emergency lights: abrupt braking, multiple collision, accident
    Regards,
    New Tiguan 2.0 TDI Executive 150CV DSG - Tungsten Silver - Sebring 7X18 et 43
    Ergo Active, Driving Profile Selection, Park Assist (Area View, Rear View, Parl Pilot), Teck Pack (Discovery Media, Signature LED e Dynamic Light Assist), Safety Pack, (Emergency Assist, Traffic Jam Assist, Rear Traffic Alert, Side Assist Plus).
    Aftermarket: Sign Assist, Start&Stop off, Day lights, Closing windows with rain, AID oro style, Fuel filling quantity.
    Formally know as fmonaldi
  4. #314
    Mar 2017
    It shouldn't effect the BT. What phone do you have? Might be the phone or firmware version? Have you tried hard resetting the phone?
    It's an OPPO R7Plus running Android 5.1.1. I don't recall this happening before I start playing with programming. Tested iPhone and no issue. So I'm suspecting its the software.
  5. #315
    Oct 2017
    Italy
    Tiguan MK2
    In case of sliping, you can activate the "Proactive Occupant Protection":
    - Front seat belt pretensioning
    - Panoramic roof closure
    - Closure of lateral crystals.
    Regards,
  6. #316
    Oct 2017
    Italy
    Tiguan MK2 - 2WD
    It can be activated - Assistant descent
    Features of 4WD Drive profile Offroad → (Driving Mode Selection)
    Regard,
  7. #317
    Hi guys,
    Thought I'd start a thread on any VCDS tweaks people have had success with. I assume most of the ones that work for the Mk7 Golf would also work but will be great to know which ones actually do work! Any screenshots, pictures, videos associated with the tweaks would be great! I'll let you guys know which ones work when I get my car and get around to borrowing/buying a cable!
    These are the ones I'm keen to do on my Tiguan when it arrives:
    1) Deactivation of auto stop/start
    2) Memory retention of seat heater setting
    3) Deactivation of seat belt reminder
    4) Activation of Volkswagen Traffic Message Channel
    5) Driving school mode
    6) Air-conditioning recirculation memory setting
    BTW, courtesy of DV52, here is the
    Mk7 Golf VCDS reference thread: MkVII VCDS Tweak - Reference thread
    He has uploaded a full BCM database, thanks to VWVY for providing his car: Mk2 Tiguan VCDS Tweaks
    CONFIRMED working VCDS tweaks:
    Activation of Volkswagen Traffic Message Channel: Mk7 Golf TSI & TDI - Observations and Questions
    Deactivation of auto stop/start (courtesy DV52 and VYWY - post #94, exactly the same way as Mk Golf 7)
    CONFIRMED working OBD11 tweaks:
    Some cosmetic changes to AID and central MFD
    (courtesy NZ_GolfR): Mk2 Tiguan VCDS Tweaks & Mk2 Tiguan VCDS Tweaks & Mk2 Tiguan VCDS Tweaks
    More tweaks: LED lights in door mirrors, DRL adjustments, refuel quanity, fan speed indicator when in auto, changing comfort blink amount, guage sweep, beep when locking/unlocking car (cheers bestyjny): Mk2 Tiguan VCDS Tweaks
    Screen nag deactivation (cheers VWVY): Mk2 Tiguan VCDS Tweaks
    Active Lane Guidance intervention settings (cheers Fried_noodles)A guide to enable EU specific features for AU Spec Tiguans
    Light Assist (NZ_GolfR): A guide to enable EU specific features for AU Spec Tiguans
    TMC, DRL option in Head Unit, Auto window closing, Dynamic Road Sign display(Cheers hoola): A guide to enable EU specific features for AU Spec Tiguans
    Easy Entry/Easy Exit seat function (NZ_GolfR): http://www.vwwatercooled.com.au/forums/f238/mk2-tiguan-vcds-tweaks-116815-18.html#post1239603
    360* Camera for Discover Media infotainment systems (Hugo_nz): Mk2 Tiguan VCDS Tweaks
    Always on rear brake light DRLs (NZ_GolfR): Mk2 Tiguan VCDS Tweaks
    Air-conditioning recirculation memory setting: Mk2 Tiguan VCDS Tweaks
    3rd rear brake light activation, Door mirror LED on with folding of mirrors, cornering fog light speed sensitivity: Mk2 Tiguan VCDS Tweaks
    AutoInstruct's OBD11/VCDS tweaks:
    https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
    Stemei.de coding: https://www.stemei.de/pages/coding/vw-tiguan-ii-ad.php
    Record of NZ_GolfR's tweaks:
    https://oncall-my.sharepoint.com/per...ding%20Changes
    Is there a tweak so that the 360 degree parking camera can be used while at speed? As they turn off after 25km/h.
    ABT Mk2 Tiguan - Fully Loaded
  8. #318
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by ABT 162TSI MK2 Tiguan View Post
    The maximum speed allowed is 20km/h. I have tried setting it higher but it refuses to code.
  9. #319
    Oct 2017
    Italy
    Instructions to set speed?
  10. #320
    Jul 2016
    Hi Guys, anyone know of a way to disable the headlight wash function please?
    cheers
    Gary
    2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
