The LED lights in the underside of the mirrors are normally off while in the process of folding in and out. This tweak turns it on.
Here is a video - YouTube
3rd/High-Mounted Brake Light Tweaks - Instructions
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Standard setting column
- For the wanted options, change the adaptation channels depicted in the table below to the values in the appropriate column (tip: use the "Search" box to locate the channels)
Avoid Dimming LED Headlight DRLs when Indicating Golf Mk7
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(12)-Leuchte2SL VLB10-Lichtfunction E2
Select: not active
(12)-Leuchte3SL VRB21-Lichtfunction E3
Select: not active
The following changes removed the "wink" feature. Those that don't like the feature this is for you.
- Golf Mk7 Disable Turn Signal Wink (alternative instructions)
- Module 09 - Central Electronics
-Leuchte3SL VRB21-Lichtfunktion C 3 Blinken rechts aktiv (beide Phasen) —> Not Active
-Leuchte5 TFL RB32-Lichtfunktion C 5 Blinken rechts aktiv (beide Phasen) —> Not Active
-Leuchte2SL VLB10-Lichtfunktion C 2 Blinken links aktiv (beide Phasen) —> Not Active
-Leuchte4TFL LB4-Lichtfunktion C 4 Blinken links aktiv (beide Phasen) —> Not Active
Automatic Window Closing in Rain
- Go into Module 09 Central Electronics
- Go into Security, use 3134 as the security code.
- Select Adaptations, and then ZV Komfort
- Select Regenschliessen_ain_aus, toggle to Active. The default is "not active"
- Then select Regenschliessen_art, toggle to Active. The default is "not active"
- Finally select Menusteuerung Regenschliessen, toggle to Active. The default is "not active"
- This enables Automatic closing in rain as a menu option under Window Operation
Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
Security access
Security Code 31347
Adaptation
(3) Static cornering light lower speed threshold
New Value=0
(4) Static cornering light upper speed threshold
New Value=50
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
Thanks veew. Much appreciated.
Came across these new tweaks on AutoInstruct website:
Haldex All-Wheel-Drive Adjust Traction
Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
Select AWD Control Unit
Adaptation
Logic
Choose from ‘Standard, Increased Traction, Less Noise’
Closing Windows When Ignition Off
Allows you to operate all windows after the ignition has been switched off and doors opened.
Security access
Access Code 31347
Adaptation
(13) – Zugangskontrolle 2 released trailing FH cancel at Tueroeffnen
Value = Aktif
My friend currently has my OBD2 and tablet so won't get a chance to try it anytime soon.
Current:
Good day all, Has anyone successfully configured and tested the "Automatic Window Closing in Rain" feature?
I've configured it but haven't had a chance to test it as no rain so far. However, I noticed that option for Auto window closing in the car menu automatically untick every time I restart the car. Does anyone who have this setting have the same issue?
I have coded and tested and mine seems to be one of the cars that it just won't work on. I get the option in the menu as well and it remains ticked permanently. So not sure why yours resets when you start. I have recorded in different orders etc... But mine refuses to work.
Just tested my car. Didn't work regardless of whether the car was locked or unlocked.
My setting in the options menu is ticked permanently as well. Pity
Current:
That's a bummer. I also just discover an issue with my bluetooth and wondering all this coding somehow stuffs it up. My Android phone keep dropping off bluetooth connection with the car every few mins. I can reconnect but it will just keep dropping. Anyone else have this issue or all iphone users in this forum?
