Originally Posted by
NZ_GolfR
Here is the coding to enable Rear DRL. This works on the LED Lights that come with the NZ R-Lines, not sure if it works with any other type of rear lights.
Central Electronic (09) - Adaptation - Leuchte16BLK SLB35BLK SL KC9 - Lichtfunktion B 16 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
Central Electronic (09) - Adaptation - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - Lichtfunktion B 17 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
Central Electronic (09) - Adaptation - Leuchte23SL HLC10 - Lichtfunktion B 23 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
Central Electronic (09) - Adaptation - Leuchte24SL HRA65 - Lichtfunktion B 24 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
There is option in there to adjust the brightness as well however I haven't changed this setting as it will potentially make the park lights too bright at night time.
Just wondering if you can point me to where the brightness settings are. Might play around with that when I get a chance.
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
