Page 29 of 118 FirstFirst ... 1927282930313979 ... LastLast
Results 281 to 290 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #281
    Sep 2017
    Tiguan tweeks
    Quote Originally Posted by veew View Post
    OBDEleven - The new kid on the block!MkVII VCDS Tweak - Reference threadYou could ask for other members for their time & tools/insight/experience or buy the bluetooth OBD dongle yourself (and an android device if you don't already have one).To buy: OBDeleven Diagnostic System – Audi, Skoda & Volkswagen – AutoInstructIf you don't have an android device already: Andriod Devive Recommendations for OBDelevenThen check out the original post for all the tweaks.
    Ok sweet.. just wish I could do it through snap on scanner.
  2. #282
    Jul 2016
    Can't remember if someone has already posted air-recirculation memory setting but this is what worked for me:
    1. 08 Auto HVAC
    2. Long coding
    3. Byte 4
    4. Bit 4-5 use drop down box and select “10 Recirculation Air settings (after ignition cycle) stored
    (Automatic Air Recirculation - VW Golf Mk7 VCDS How-To)
    Thank you!!!!.... been wanting to do this!....Cheers veew.
    2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
  3. #283
    Nov 2013
    AUS
    OBD11 - Trailer electronics activation
    For those of you with towbars installed, do you have the following in your Central Infotainment Display?
    If you go to Menu --> Vehicle --> Settings --> Drivers Assistance: Do you have trailer recognition sub-menu?
    Mk2 Tiguan VCDS Tweaks-img_0323-jpg
    (YouTube)
    It wasn't there originally for me but I coded it in the Trailer Module:
    Mk2 Tiguan VCDS Tweaks-1-png
    Mk2 Tiguan VCDS Tweaks-2-png
    Mk2 Tiguan VCDS Tweaks-3-png
    Mk2 Tiguan VCDS Tweaks-4-png
    There are a few other trailer related settings I was going to code but didn't want to do too much before actually trying out something on the towbar. I just want to know if Trailer Assist where you use the mirror adjuster can be used to place the trailer whilst reversing.
    Will eventually get more time to find out the answer if someone else hasn't already beaten me to it.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #284
    Sep 2017
    Yep I have it. I can't wait to try it though. See how good it is
  5. #285
    Nov 2013
    AUS
    Quote Originally Posted by Paul RLine View Post
    Just interested in knowing a few things about your vehicle.
    What are the specs of your vehicle? Trim level and model year?
    What towbar do you have? VW Genuine or Westfalia or other?
    Current:
  6. #286
    Aug 2017
    Uk
    i have a 2017 facelift golf with trailer assist factory fitted, if that's any help (I can look at the codings Monday (uk time) if that's any help)
  7. #287
    Sep 2017
    It's this year built in June. R Line trims. Genuine tow bar. Actually I'll double check that
  8. #288
    Sep 2017
    I have this year June build with RLine
    Vw fitted not exactly sure of brand. I'll double check
  9. #289
    Apr 2017
    Beachlands, Auckland
    Quote Originally Posted by Jap View Post
    Hi Jap
    Please could you post your codings & adaptation channels so I can compare. I followed these instructions on my MY17 Tiguan R-Line:
    Activate Trailer Assist - VCDSSchweiz
    I had the genuine trailer electrics installed by dealer, so car knows when trailer plugged in, but Trailer Assist never worked. After altering the above coding & adaptations, I now get a message that Trailer Assist is available and to press the Park Assist button when the car is in reverse - once I do that, a picture flashes up showing how to control via the side mirror selector/adjuster, but then an error message comes up to say take control of the steering wheel as Trailer Assist is not available due to the reversing camera being obscured.
    I have no idea why this error occurs, as the camera is clean, I have removed the jockey wheel & re-routed the trailer plug out of view in-case it is getting confused.
    I did have a problem with the final adaptation change, as Klemme 15 does not appear in the drop down list??
    Any assistance would be greatly appreciated.
    Aug 2017
    Uk
    Backup
    Control unit: 69 Trailer Function
    System description: Anhaenger
    Software number: 5Q0907383H
    Software version: 0204
    Hardware number: 5Q0907383C
    Hardware version: H21
    Serial number: 0428187970
    ODX name: EV_TrailFunctGener2Hella
    ODX version: 001008
    Backup name: trail
    Long coding:
    0100000202000000
    Adaptations:
    Production mode:
    Activate start-up mode:
    not active
    Control module switch-off, counter:
    Control module:
    0 min
    Data bus:
    0 min
    Control module switch-off, switch-off time:
    Control module:
    30 min
    Data bus:
    15 min
