Page 27 of 118 FirstFirst ... 1725262728293777 ... LastLast
Results 261 to 270 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #261
    Jun 2017
    Adelaide. South Australia
    Quote Originally Posted by NZ_GolfR View Post
    Here are the exact details for the changes using OBDeleven:
    Control unit: 09 Central Electrics - Adaptions - Int. light, 2nd generation - Instrumententafelbeleuchtung mehrfarbig - Set to Active
    Control unit: 09 Central Electrics - Adaptions - Interior light, light configuration - Ambient_Farbliste_HMI - Set to Active
    Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set your RGB Values for all 10 Colour options (Rotwert = Red, Gruenwert - Green, Blauwert = Blue)
    Once you have applied the codings reset the Infotainment unit (hold power button down until system reboots) then go into Car - Settings - Background Lighting and you can switch from Brightness Setting to Colour Setting. Change the colour here changes it in the Discover Head Unit as well as the AID.
    So it comes up in the main vehicle settings menu? I can’t seem to find it.
    Sent from my iPhone using Tapatalk Pro
  2. #262
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by jbaldy View Post
    When you press the Car button and then the Settings button down the right hand corner of the radio you should have an option for Background Lighting. In there you should be able to switch between brightness and color options.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #263
    Apr 2017
    JHB, South Africa
    Great work NZ_GolfR. Any literature on the colour options for RGB for all the 10 sections. Once you have put colours in can you change it from the menu or must you go into programming again?
  4. #264
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by cabby09 View Post
    You can set the 10 options to any rgb values your heart desires. If you followed the steps those 10 options will be selectable from the Car menu. To make changes to the 10 options you have to change the rgb values in OBDEleven.
    Use this link to get the rgb values you desire: HTML Color Picker
  5. #265
    Apr 2017
    JHB, South Africa
    Quote Originally Posted by Hugo_nz View Post
    Thanks Hugo... Makes more sense now
  6. #266
    Jul 2017
    Auckland, NZ
    No worries
  7. #267
    Nov 2013
    AUS
    Is it possible to code the side mirror lights to illuminate when using the 360* camera view at night or when reversing at night? Would make my life easier not to kerb the rims.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  8. #268
    Aug 2017
    Netherlands
    No worries
    Do you have any favorites to share with us?
    I Would like to keep the colors the same as the "original ones" like you first selected with OBD on the AID itself (GTI R/native blue etc.)
  9. #269
    Aug 2017
    Uk
  10. #270
    Aug 2017
    Uk
    seems the 9.2 descover pro has a different menu system than the other one, so no changing of colour in the setup screens
