So this just changes the colour of the central display? Does it affect the colour of the ambient lighting in the doors etc?
Current:
2017 Mk2 Tiguan 162TSI, R-line, White
2020 Mk7.5 Golf R Wagon, White
So slight twist of events. Went to try and code in the gold colour so I could have the Infotainment unit match the AID and when I set the AID Display Depiction to Version 3 it was no longer gold. It seems with setting the custom colour options it now inherits whatever you have it set to:
Here are a few other examples of the matching colours:
Not the best photos, sorry, as it was dark.
One thing to note I have discovered with the custom colours, all 10 have to best set. If any of them have the RGB value set to 0, 0, 0 then it doesn't work.
Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
I think it's done in central electronics so changes both at same time
wheres the settings listed in the mib to get the colour menu up?
Here are the exact details for the changes using OBDeleven:
Control unit: 09 Central Electrics - Adaptions - Int. light, 2nd generation - Instrumententafelbeleuchtung mehrfarbig - Set to Active
Control unit: 09 Central Electrics - Adaptions - Interior light, light configuration - Ambient_Farbliste_HMI - Set to Active
Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set your RGB Values for all 10 Colour options (Rotwert = Red, Gruenwert - Green, Blauwert = Blue)
Once you have applied the codings reset the Infotainment unit (hold power button down until system reboots) then go into Car - Settings - Background Lighting and you can switch from Brightness Setting to Colour Setting. Change the colour here changes it in the Discover Head Unit as well as the AID.
Man the car is getting better and better! Bit annoying VW releases their cars "dumb"...
Btw I know others have done so, but thanks to all that have contributed to this thread! I will get around to updating the OP again soon.
Current:
