Page 19 of 118 FirstFirst ... 917181920212969 ... LastLast
Results 181 to 190 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #181
    Jul 2016
    Quote Originally Posted by Hugo_nz View Post
    So far mine has shown 2 signs. I drive pretty much the same routes every day so never really get the chance to drive past different signs.
    Im sure Ive seen photos here on the forum with the speed signs showing up above the main display, on the right side of the clock. Is there a setting somewhere ive missed?
    2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
  2. #182
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by Regdop View Post
    No, if you have the main display showing something else (speed, navigation, music etc) then it moves the speed sign Display up the top next to the clock:
    Turning the Traffic Sign Recognition on give you the ability to also be able to view it in the main screen under where you can choose from your speed, oil temp, usage etc which is what you saw in Hugo_nz image.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #183
    Jul 2016
    Quote Originally Posted by NZ_GolfR View Post
    Ah.... that makes sense.... cheers!
  4. #184
    Apr 2017
    Hi
    Do you have any ideas why I'm getting signs with white square surroundings instead of pure sign with the red circle?
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by zzc2010 View Post
    Hi
    Not sure, can you post up a picture of what you are getting?
  6. #186
    Jul 2010
    Brisbane, Queensland
    Quote Originally Posted by artful View Post
    Hi NZ_GolfR,
    Just try it on my VCDS i can't find it anywhere in VCDS. Do you know where should i look out?
    Hey NZ_GolfR i am the same as artful... using VCDS and I can not find this mod adaption anywhere. Is it possible you could provide more specific info to help us VCDS users out? Cheers
    Current: MY17 VW Tiguan Highline 162TSI - Pure White, R-Line, Driver Assistance Pack, Sunroof
    MY14 Audi S3 Sedan, Misano Red, Performance Pack, Sunroof
    MY11 VW Golf R - Candy White. Bluetooth, MDI, Sunroof, RNS510
  7. #187
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by GolfR79 View Post
    Sorry but I don't have VCDS so I can't check the settings in there. Can you send through a list of adaption channels you can see in that module under VCDS and I will see if anything matches?
  8. #188
    Jul 2010
    [QUOTE=NZ_GolfR;1239865]Sorry but I don't have VCDS so I can't check the settings in there. Can you send through a list of adaption channels you can see in that module under VCDS and I will see if anything matches?
    Thanks NZ_GolfR, for VCDS users module 9 is titled Cent. Elect. below is the screenshot from the drop down list of adaptions starting from the top.
    Mk2 Tiguan VCDS Tweaks-module-9-jpg
  9. #189
    Aug 2016
    Auckland, NZ
    [QUOTE=GolfR79;1239875]
    Sorry, my mistake it is under the Dash Board module which is module 17 (not 9 like I had said). Have a look and see if you can see the adaption listed under there.
    I will edit my original post with the correct module number.
  10. #190
    Apr 2017
    Thats what im getting in my AID
