Also if anyone is interested I found that if you have electronic seats you can turn on the Easy Entry/Easy Exit function:
Seat Adjustment Driver Side (36) - Coding - Easy_Entry_front - Change to Active
This will slide the seat all the way back when you turn the car off to allow you to get it out and then when you get back in and turn the car on it slides forward to the saved position.
