Page 15 of 118 FirstFirst ... 513141516172565115 ... LastLast
Results 141 to 150 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #141
    Apr 2017
    Quote Originally Posted by Hugo_nz View Post
    It's road set to "Detect" not "Fusion". It does give a limited function warning, but it works as expected ie., it picks up the road-side signs and also temporary signs which have been placed for road-works.
    Hi
    Mine TSR functions the same as yours but it presents signs with white background and surroundings.
    Is it the same as yours?
    Also, my car only picks up the speed signs but no others in Sydney.
    My A5 firmware is fairly old 0220 maybe thats the reason.
  2. #142
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by GeeMoney View Post
    The camera should also be there already? Or did you build it in?
    My car has surround view fitted. I enabled the 360 feature via OBDEleven.
  3. #143
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by zzc2010 View Post
    Hi
    So far mine has shown 2 signs. I drive pretty much the same routes every day so never really get the chance to drive past different signs.
  4. #144
    May 2017
    Sweden
    Quote Originally Posted by bestyjny View Post
    Ok, so here are few from me All tested and working. I dropped those from NZ_GolfR to avoid duplicating.
    - LED lights in door mirrors light, even in close:
    Modules 42 and 52 -> Coding -> Byte 01 -> Bit 5 deactivated
    - DRL off when lights switch on position "0", but on when "AUTO":
    Module 09 -> Security Access enabled -> Adaptation -> search for "ENG115734" and change to inactive
    - DLR option to switch on/off from menu (independent from above tweak):
    Module 09 -> Security Access enabled -> Adaptation -> search for "ENG116594" and select from dropdown "Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich" -> change to active
    Now you can go to Car Setup menu and you'll find extra tick to enable/disable DLRs.
    - Refuel quantity on AID as one of Driving data options:
    Module 17 -> Coding -> Byte 10 -> Bit 4 activated
    - Fan speed indicator (leds around button) when in AUTO mode:
    Module 08 -> Coding -> Byte 11 -> Bit 6 activated
    - Disable "ingnition on" alarm, when drivers door open:
    Module 17 -> Adaptation -> search for "ignition" and select "actuator should appear as the only entry" from list -> change to "No display"
    - Changing "blink" number on comfort blinkers:
    Module 09 -> Security Access -> Adaptation -> select "Turn Signal Controls-Komfortblinken Blinkzykien" -> change between 1 and 5
    - Gauge/Needle sweep on AID
    Module 17 -> Coding -> Byte 01 -> Bit 00 activated
    - "beep" when lock and unlock car doors
    Module 09 -> Security Access -> Adaptation -> search for "acknowledgement" and depending what you want, select active or inactive for available options with "Akustische" in description
    I tried to change to the "gold display", but cannot access "adaptations" in module 17 with vcds.
    Skickat från min SM-G950F via Tapatalk
  5. #145
    Aug 2016
    Auckland, NZ
    I enabled the 360 camera feature today. Pretty neat. Check out thevideo:
    https://www.youtube.com/embed/hhwCUR1k0Wg
    How about that, I already had this enabled on my car yet never knew it was there Mk2 Tiguan VCDS Tweaks Guess I am still finding new features even 8 months down the track!
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  6. #146
    Dec 2016
    Quote Originally Posted by NZ_GolfR View Post
    Will that be on the new my18 ?
    MY18 Tiguan Highline 162TSI - DSG - Driver Assistance Package Sunroof- R-Line Package - Indium Grey. Oct Delivery
  7. #147
    Feb 2017
    SE Melbourne, VIC
    Quote Originally Posted by Eyes24 View Post
    Just checked mine and have the 360 deg view, didn't realise it was there either
    MY17 Tiguan 162 Highline | DAP | Rline | Pano Sunroof | Pure White
    Stage 2.5 - APR DP, APR Turbo inlet, Muffler delete, IS38 Turbo, APR tune
    MY18 Tiguan 162 Highline AllSpace | Sound & Vision | Sunroof | Blue Silk
  8. #148
    Dec 2016
    Quote Originally Posted by TheTig View Post
    Very cool, did u have to enable it?
  9. #149
    Aug 2016
    Auckland, NZ
    No. I think if you have the Discover Pro and Area View then it is turned on by default. I know Hugo_nz has the Discover Media so this tweak might just be for that head unit.
  10. #150
    Nov 2013
    AUS
    Awesome!
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
