Page 99 of 118 FirstFirst ... 4989979899100101109 ... LastLast
Results 981 to 990 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #981
    Feb 2018
    Thanks for your reply Don.
    I'm actually using OBD11.
    I looked through every line, and couldn't find find anything relating to "SAD", "Sunroof" or "Komfortoeffnen". I'm also hesitant to start activating/de-activating things randomly.
    I'll have another go tonight.
    Cheers,
    Dan
  2. #982
    Pacific Paradise QLD
    Youu could try in long coding Byte 3 has Comfort closing sliding roof, Comfort opening sliding roof. and Comfort opening type sunroof
    Byte 4 also has alternatives
  3. #983
    Quote Originally Posted by AshB View Post
    maybe dynamic roadsign display, though i'm not sure how this is meant to work?
    I got my MY20 Highline last week and my OBDeleven device on Tuesday. Used 100 credits to run the roadside display app, which OBDeleven said was successful, but the dash flashed up with an error message (didn't quite catch what it said - but something like 'not supported'), but it doesn't seem to work at all.
    It did all a "roadsign data" (or similar) option into the the driving data screen in the AID, but it just says there is no data.
    Anyone else got this working on a MY20?
  4. #984
    The only way anyone has got it working is using the instructions posted by Phone booth The APP doesnt work at all
  5. #985
    Ok thanks, will try that. That was a waste of 100 credits I guess!
  6. #986
    Hey guys, I have a few questions and I'm gonna write them here in one post no to clutter the thread.
    1. so I tried coding my tiggi to recognise speed signs and I believe I have missed something or perhaps my R-line doesnt' have the capability to do it but now I'm stuck with error. Does anyone know how to fix it, I sort of followed the steps and tried to reverse the changes ... I must be missing some step.
    Imgur: The magic of the Internet
    Mk2 Tiguan VCDS Tweaks-dynamic-road-sign-error-jpg
    2. When you are driving in the area you are not familiar with sometimes it's nice to have the info displayed on the map what road you are on. I found that when driving in left top corner of the main display it shows what drive mode is on, however when you switch off the engine it displays the road name. I was thinking there should be an option to code and have street name displayed while driving too. I mean who really wants to know if you are in normal or sports mode.
    Mk2 Tiguan VCDS Tweaks-maps-driving-jpg
    Mk2 Tiguan VCDS Tweaks-maps-parked-jpg
    3. I bought my tiggi brand new and it had this weird glitch on both screens when you get in the car and start the engine. I have a feeling it's got something to do with firmware? Anyone has the same issue? I'm thinking to take it to dealership and get it checked.
    Mk2 Tiguan VCDS Tweaks-dash-squares-jpg
    Mk2 Tiguan VCDS Tweaks-display-funny-vw-logo-jpg
    4. There's also a blue line on the screen when the maps are on, not all the time but it seems to come and go. You would think it's water border however it appears even in the city.
    I have attached photos but not sure if they will be big enough to see so there links bellow with original size bellow.
    Thanks in advance
    https://imgur.com/DMjDTNJ
    https://imgur.com/m1OKevW
  7. #987
    Thanks in advance
  8. #988
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by tsameti View Post
    Thanks in advance
    I can only address item number 4, but unfortunately it seems to be a fairly common issue - you’ll need to take it back to the dealership and they’ll swap out the Discover Pro unit for a new one. Happened to me too.
    I imagine this may also fix item 3, which definitely isn’t normal.
  9. #989
    Got the Road Signs working on my MY20. After running the OBDeleven app, I then I went into Module A5 / Adaptations / changed 'Road Sign Detection' from 'Fusion' to 'Road Side Detection' and it works!
    Mk2 Tiguan VCDS Tweaks-roadsign-jpg
  10. #990
    Quote Originally Posted by ajobbins View Post
    Yes that has to be done but if you use coding you dont need credits
