Page 98 of 118 FirstFirst ... 488896979899100108 ... LastLast
Results 971 to 980 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #971
    Jun 2019
    OK, what am i doing wrong with trying to post my code.
    I go advanced, select the #, then paste the code between the [] [].
    My code is a full log, 42000 odd characters, is that the issue?
    I just did exactly the same thing on the RT Forum, and it accepted my code. Maybe it’s a post count thing.
  2. #972
    Jan 2019
    Camden, NSW
    Ah, I received the new OBDEleven last week, and finally got around to using it last night, made some minor tweaks to get started,
    * Enabled TMC traffic, this was working the next morning on my way to the station.
    * Disabled startup nag, ah, peace at last.
    * Disabled undertake on left prevention, I look forward to never worrying about this again.
    Already my life is better.
    I'm running on an MY19.5 R-line SWB
    I plan on enabling Dynamic Light Assist next, and see if I like the Reduced throttle delay
    maybe dynamic roadsign display, though i'm not sure how this is meant to work?
  3. #973
    Pacific Paradise QLD
    Quote Originally Posted by AshB View Post
    Read through the thread its all there and it doesnt work quite as good as it could due to our mapping limitations
  4. #974
    Jan 2019
    Camden, NSW
    That is what I thought. Oo this is the speed sign that appears on the maps, sometimes. I haven't really used the built in maps much, given my area is all new developments, the maps aren't updated often enough to be of much use, so I rely on car play.
  5. #975
    May 2018
    Brisbane QLD
    It's works, the speed limits also come up in the display. It's works using the camera not maps.
    Sent from my SM-G977B using Tapatalk
  6. #976
    Quote Originally Posted by twyat1 View Post
    Does it really Tell me then why historic speed signs that are NO LONGER THERE come up at random places and do it repeatedly..
    Where does that info come from????
  7. #977
    If you look in this thread you will get the latest map which came out on Nov22nd
    Link is in reply 4
    Latest map for DIscover Pro out
  8. #978
    Nov 2019
    Ballarat, Vic.
    My Highline is to be delivered Friday and I would like to do the same things, but that's all.
    Does anyone in the Ballarat, Victoria region have a OBDEleven or VCDS who would be prepared to help me do these mods?
  9. #979
    Feb 2018
    Hi,
    I've been trying to activate the Sunroof Opening/Closing With Remote Control using this coding:
    Sunroof Opening With Remote Control
    Sunroof opens when holding down the unlock button on the key fob. Also closes when holding lock button.
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
    Change to Active
    When I go into Adaptation, I can't find (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen
    It simply isn't there.
    Does anyone have any tips/assistance for me please? It's a 2017 Comfortline with DAP and Lux.
    Cheers,
    Dan
  10. #980
    ^^^^ Dan: it really does depend on the car's build year and as a consequence - what model BCM (the hex09 module) is fitted. There was a major re-write of the "Parent" names in the adaptation channel database for the BCM around mid 2016 and lots of stuff changed.
    Also the name for the channel in your post looks like it came from a very old version of VCDS. Assuming that you are using VCDS - the modern SW no longer reports adaptation channel with leading number in parentheses. Now, these channels have a set of leading "Tag numbers" : one for each of the Parent and child names.
    Of course, if you are using OBD11 - there are no parentheses, or Tag numbers
    Instead of your channel (9) – Zugangskontrolle 2 – SAD Richtung Komfortöffnen auswählen- try looking for looking for ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen
