Page 96 of 118 FirstFirst ... 46869495969798106 ... LastLast
Results 951 to 960 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #951
    Aug 2018
    How much do you want for yours?
    I'm thinking of getting one.
    2018 Allspace 162TSI R Line
  2. #952
    Oct 2015
    Danintas, everything can be done and undone by long coding. The credits/apps(or whatever they’re called) are shortcuts for POTENTIAL features of VW vehicles. Nothing is guaranteed to automatically work on Australia market tiguans/golfs/etc.
    Coding (still easy) is the best way to play.
    Feel free to sell yours/bin it, but learn from the experience- don’t blame the tool.
  3. #953
    Pacific Paradise QLD
    Quote Originally Posted by danintas View Post
    My advice is NOT to buy OBD11, and if you already have, chuck it in the bin. It has cost me a heap of credits to activate High Beam Assist, then deactivate, and then revert to original. Support is woeful.
    Hardly their fault you didnt follow what has been posted about it and the app DOES work because I did it on mine no trouble. Also you can just revert it back and not need 3 lots of credits or could even have coded it back for free
    Does you vehicle meet the criteria HIGHLINE ??????? Lots more tweaks available and not a credit used In fact I have 621 saved up and not needed
    If you used coding it wouldnt have cost you anything and the coding for that is on the Autoinstruct site as per here and it DOES WORK
    Enable Auto High Beam (Light Assist)
    Enables the Auto High Beam for Highline Models Only.
    Workman, Tools blame???????
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’
    2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
    Enter Coding
    Byte 2 – Tick Bit 0 and Bit 1
    Select Control Unit Front Sensor Driver Assist System (A5)
    Enter Coding
    Byte 21 – Tick Bit 5
    Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.
  4. #954
    Wink
    Quote Originally Posted by Simonr23 View Post
    Hes blaming the wrong tool ROFL
  5. #955
    Nov 2019
    Italia
    Closing windows & sun roof with 1 click on key remote
    Hi... someone have this coding for MK2 Tiguan..!?
    Thanks.
    YouTube
  6. #956
    Feb 2018
    Blog Entries
    1
    Security access
    Access Code 31347
    Adaptation
    Enter Coding
    Enter Coding
    Followed directions and was going well until the last step.
    Selected A5 entered the long coding but no Byte options came up, help please I'm only new at this so be patient.
    How do I attach photos to a thread?
    MY18 Tiguan R Line Black-162 Highline TSI
    Drivers Assistance Package - Sunroof - Tow Bar
    Ordered July 17 Arrived December 17 Delivery Jan 18
  7. #957
    Quote Originally Posted by Wazza 162 View Post
    USe the 'Go advanced button and follow prompts
    When u entered A5 did you scroll along to byte 21
  8. #958
    Feb 2018
    Blog Entries
    1
    There was no Byte options like the control unit 09
  9. #959
    To the right of long Coding at the top is a little box with O and 1 on it press the right side of it and magically what you want will appear
  10. #960
    Feb 2018
    Blog Entries
    1
    Learning a bit more with each step but still not showing in the light settings.
    Byte 5 isn't shown but I presume it's the light assist box, there are 2 more unlisted boxes under that one do I leave them alone?
    Close to giving up but I must be close to activating HBA.
    THANKS for your patience.
