Page 92 of 118 FirstFirst ... 42829091929394102 ... LastLast
Results 911 to 920 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #911
    Feb 2019
    Perth, WA
    So far I've been able to get the following working on my '19 Highline SWB.
    1. Undertaking prevention disabled.
    2. Traffic info display.
    3. High beam assist.
    4. Traffic sign recognition.
    Will attempt Dynamic Light Assist once I've built up the courage and read through some of the issues people have had coding it.
  2. #912
    Pacific Paradise QLD
    Quote Originally Posted by phonebooth View Post
    I have done following
    Turned off Stop start
    Enabled Speed sign recognition
    Enabled Litres on filling
    Turned off nag on Nav
    Changed ambient light colours on dash to 10
    Changed rear lights to be on with DRL's
    Changed rear turns to be on 50% brightness when boot open
    Enabled Needle sweep
    Enabled pass on left
    Enabled traffic information
    Changed several warning levels
    Raised microphone sensitivity
    Enabled HBA
    Changed display to GTI
    Cant enable battery level.
    Dont have headlight washers
    Seem to have enabled Dynamic Light Assist (Thanks to Phonebooth)
  3. #913
    Nov 2016
    MAPLETON Qld
    Too me quite a while to get the courage to code DLA, but it was mainly persistence after several failures and stuff ups.
  4. #914
    Feb 2019
    Perth, WA
    Quote Originally Posted by Hole46 View Post
    Did you follow the instructions from Activate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding ?
  5. #915
    Nov 2016
    MAPLETON Qld
    Yes
  6. #916
    Far better to do it from here especially if you have an OBDeleven
    Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
  7. #917
    Nov 2013
    AUS
    I have done following:
    Where did you find the instructions for this?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  8. #918
    Quote Originally Posted by veew View Post
    Is an app on OBD eleven which you need to do it
  9. #919
    Feb 2019
    Perth, WA
    Looks like they've removed the Dynamic Light Assist coding from their page. Only has HBA now.
  10. #920
    Enable Auto High Beam (Light Assist)
    According to the full spec sheet of mine it says this
    Dynamic Headlight range control with cornering lights (AFS)
    They change what they call things so who knows what we have
