Maybe those with the new AID / a proficient understanding of Russian can shed more light on this, but it seems like the interface can be adjusted?
I know that via obd11/vcds you can change which dash theme is displayed on the v1 AID- from several vw models.
This looks to be the same?
Thanks for that Will have a look at mine but mostly I didnt get that far into the coding to be able to.
Have changed that but I guess I will have to try to recode the whole thing as after I got the 'Not supported" notice it looked like the settings I changed had reverted back to original. Will be using it ant night on Sunday so we will see
UPDATE
SUCCESS
Had to change a couple of things Like extra headlight LED and do what you said and it shows the correct symbol in the dash anyway, when I have headlights on and push the stalk away from me
couldnt figure out how to get the A5 to show in hex but worked out little sign in top of phone screen changes it into hex from English.
I changed it as you did but also did the hex settings and iit seems to have done it Now to see if it works on Sunday
To be perfectly honest in the video that supposedly shows it working I couldnt tell the difference between it on or off
