Page 89 of 118 FirstFirst ... 3979878889909199 ... LastLast
Results 881 to 890 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #881
    Oct 2015
    I suspect that the right (and lengthy/complex) combination of settings changed in obd11 coding will achieve it.
    I wish the language was in English, as I’m fairly sure I could sort it out. I google translated my way through several things already, but even then it wasn’t always a straight, logical interpretation.
    It’s still possible that it’s been hard-locked and needs an official, licenced device to interrogate the car, to enable a certain function?
  2. #882
    Pacific Paradise QLD
    Not hard to follow in OBDII if you go to long coding it is easy to follow but when you get to a certain point and enter it it just comes up with a red box saying NOT SUPPORTED
    Have tried 5 times altogether and its always the same
    Here is the instruction Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
    Scroll down to 'AutoHigh Beam" Light assist
  3. #883
    Oct 2015
    Get in-depth in the long coding and come back with ‘easy to follow’ . As lots of things start getting acronyms- in German, it can be hard to know what small setting is being changed.
    I was playing around with various sunroof settings. There are thousands of options that can be changed in the various modules. Lots are dependent on other changes to be
    A- effective.
    B- not cause an error.
    C- break something else.
  4. #884
    Jun 2013
    Qld
    Quote Originally Posted by Simonr23 View Post
    They’re the same as the highline swb lights. One big eyebrow of drl, with a ‘U’ shape also tracing the low beam.
    If the drl’s aren’t that design, then the headlights themselves can’t do DLA. Now whether the correct computers/software are installed...
    Also it’s not only headlight type. You need the camera mounted in windscreen to have Dynamic light assist (DLA) working properly. In my case it came with Driver assist pack
  5. #885
    Quote Originally Posted by jeromeo View Post
    I have all of that Have DAP and Sound & Vision but it isnt included in DAP in a shorty, only in an Allspace according to the brochures and specs for the two
  6. #886
    Oct 2018
    Melbourne, VIC
    Strange that it won’t work. Maybe it’s an MY19 issue, as none of the earlier models have HBA listed, yet can get it activated via coding.
  7. #887
    Quote Originally Posted by PDMJO View Post
    My MY19 was built on NOV 22nd 2018 and it wont do it also the brochures for the shorty dont list it but the one for the Allspace does.
    Would be good if you can tell us how to code it
  8. #888
    Oct 2018
    Melbourne, VIC
    I’m not much help in that area. I followed the same guide from AutoInstruct, however, one of the adaptations was called something different to that of what is listed in the guide. That’s the only thing I did differently.
  9. #889
    Have you got a shorty or an Allspace Its called Dynamic Light assist in the Autoinstuct list of tweaks and doesnt work on mine.
    Its not in the DAP either for mine but is for an Allspace
    If you did something different what was it you did??????
  10. #890
    Oct 2018
    Melbourne, VIC
    I’ve got the SWB.
    Like I said, all I remember is that the adaptations were called something different to what’s listed in the guide, so I modified the equivalent one.
