Page 88 of 118 FirstFirst ... 3878868788899098 ... LastLast
Results 871 to 880 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #871
    Pacific Paradise QLD
    Have managed to do or not to do the following
    (High Beam assist ) doesnt on the TIguan as we dont have the correct lights to do it.
    Ive tried 4 times and a VW expert told me that the headlights arent the ones with the ability to shut off some of the LED's
    Also we cant do the pace car turn indicators because we only have single piece turn's on the rears
    I have done following
    Turned off Stop start
    Enabled Speed sign recognition
    Enabled L on filling
    Turned off nag on Nav
    Changed ambient light colours on dash to 10
    Changed rear lights to be on with DRL's
    Changed rear turns to be on 50% brightness when boot open
    Enabled Needle sweep
    Enabled pass on left
    Enabled traffic information
    Changed several warning levels
    Raised microphone sensitivity
    Cant enable battery level.
    Dont have headlight washers
  2. #872
    Oct 2015
    Your ‘expert’ may be self-appointed. The tiguans with DLA don’t have matrix/multi LED headlights. It’s an assortment of mirrors/flappy things setup, combined with active beam assist(the up/down/left/right movements), which control which parts of the road get illuminated.
    It’s very possible there are cars with the correct headlights, BUT without the correct options programmed/installed in the relevant computer(s). I don’t mean ‘enabling’ disabled features, like road sign recognition.
    I wish we allspace/diesel could have the power/boost meter info display. I enjoy that sort of data.
  3. #873
    Quote Originally Posted by Simonr23 View Post
    He is the Foreman at the dealer I bought it off (Hes been there at least 6 years) and I specifically described what I wanted and he said that the headlights we have arent able to do that so I have to take his word , correct or not.
    I have had 4 attempts so get it to work and even doing long coding it says NOT SUPPORTED
    Perhaps someone with a Rosstech cable will have more success but really are only doing the same thing a different way
  4. #874
    Oct 2015
    There’s a couple of people on here who seem to know the correct terminologies and principals of the VAG systems, that can hopefully explain my perspective more accurately. I believe some features have to be ‘hard’ (read/write privileges) enabled, before they can be ‘soft’ (what obd11 and vcds do) enabled.
    I suspect the dla vs not is to do with that.
    For the record, if I try and enable my dla (already comes 100% factory enabled on allspace highlines) the obd11 way, it stops working properly!
  5. #875
    Yes would be good if someone could tell us what to do to enable it as its weird that the Allspace gets it with probably the same headlights .
  6. #876
    Jun 2013
    Qld
    I have an allspace diesel and my headlight looks different. Not the same hardware.
    Sent from my SM-G965F using Tapatalk
  7. #877
    Can anyone show a photo of them as someone has put the shorty ones on here
  8. #878
    Oct 2015
    Quote Originally Posted by jeromeo View Post
    Be aware, I mentioned highlines
  9. #879
    Oct 2015
    They’re the same as the highline swb lights. One big eyebrow of drl, with a ‘U’ shape also tracing the low beam.
    If the drl’s aren’t that design, then the headlights themselves can’t do DLA. Now whether the correct computers/software are installed...
  10. #880
    Yes Mine is a Rline and has the "mid" model lights which look the same as the Allspace.
    However i have just been reading the specs for both and the shorty doesnt mention DLA but the Allspace has it as part of the DAP package Wonder how to get it. Not that I go out ant night much but like all the toys
