Check your earth tab on your battery? Is it a little box or just a tab and bolt
I did the battery charge mod yesterday. Said it accepted it but when I do the hold the button down i get a copyright message instead of the Battery level.
Any ideas ???????????
Had my car in for a service today and found they have reset my bypass to the autostop function. Traffic alerts were untouched. Has anyone else had this happen during a service ?
I did the voltage change to disable the engine autostop. I will connect up to the car and see what the value is now, and then change it back.
Have tried to get speed sign recognition going using the app several times and it hasnt worked
This afternoon while playing I went into Module A5 Front sensors Driver Assistance System/Road sign detection Fusion Mode
Was reading Road sign Fusion
Changed it to the option which is Road sign Detection.. NOW IT WORKS
Seems the App didnt do it properly
Glad you got it sorted. Changing fusion mode is one of the steps to activate it- I’ve only done things via coding, for each feature I’ve enabled.
