Page 84 of 118 FirstFirst ... 3474828384858694 ... LastLast
Results 831 to 840 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #831
    Mar 2019
    Tried coding the DLA using OBD11 and the ascoding instructions the other day, but I think I tripped up at the “basic settings” and fault clearing stage. I think what needs to happen is to do the basic setting in the module, then acknowledge it, then clear the faults. As it was I was getting errors, so just set all long coding back to what it was before I started.
    To be honest I’m not THAT stressed about getting it working though.
  2. #832
    Mar 2019
    Gave up on the dynamic light assist and just enabled high beam assist. Coding the dynamic light assist just gave me errors in the dynamic cornering lights and I quite like them so didn’t want to have them not working.
  3. #833
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by MickyD View Post
    I was having the same error, resetting lights and clearing errors, and with a failing battery, I gave it one more try, and DLA installed.
  4. #834
    Pacific Paradise QLD
    Deleted Found answer
  5. #835
    Jun 2013
    Qld
    Quote Originally Posted by veew View Post
    Hi guys,
    Thought I'd start a thread on any VCDS tweaks people have had success with. I assume most of the ones that work for the Mk7 Golf would also work but will be great to know which ones actually do work! Any screenshots, pictures, videos associated with the tweaks would be great! I'll let you guys know which ones work when I get my car and get around to borrowing/buying a cable!
    These are the ones I'm keen to do on my Tiguan when it arrives:
    1) Deactivation of auto stop/start
    2) Memory retention of seat heater setting
    3) Deactivation of seat belt reminder
    4) Activation of Volkswagen Traffic Message Channel
    5) Driving school mode
    6) Air-conditioning recirculation memory setting
    BTW, courtesy of DV52, here is the
    Mk7 Golf VCDS reference thread: MkVII VCDS Tweak - Reference thread
    He has uploaded a full BCM database, thanks to VWVY for providing his car: Mk2 Tiguan VCDS Tweaks - Page 8
    CONFIRMED working VCDS tweaks:
    Activation of Volkswagen Traffic Message Channel: Mk7 Golf TSI & TDI - Observations and Questions - Page 56
    Deactivation of auto stop/start (courtesy DV52 and VYWY - post #94, exactly the same way as Mk Golf 7)
    CONFIRMED working OBD11 tweaks:
    Some cosmetic changes to AID and central MFD
    (courtesy NZ_GolfR): Mk2 Tiguan VCDS Tweaks - Page 26 & Mk2 Tiguan VCDS Tweaks - Page 10 & Mk2 Tiguan VCDS Tweaks
    More tweaks: LED lights in door mirrors, DRL adjustments, refuel quanity, fan speed indicator when in auto, changing comfort blink amount, guage sweep, beep when locking/unlocking car (cheers bestyjny): Mk2 Tiguan VCDS Tweaks
    Screen nag deactivation (cheers VWVY): Mk2 Tiguan VCDS Tweaks
    Active Lane Guidance intervention settings (cheers Fried_noodles)A guide to enable EU specific features for AU Spec Tiguans
    Light Assist (NZ_GolfR): A guide to enable EU specific features for AU Spec Tiguans
    TMC, DRL option in Head Unit, Auto window closing, Dynamic Road Sign display(Cheers hoola): A guide to enable EU specific features for AU Spec Tiguans
    Easy Entry/Easy Exit seat function (NZ_GolfR):
    http://www.vwwatercooled.com.au/forums/f238/mk2-tiguan-vcds-tweaks-116815-18.html#post1239603
    360* Camera for Discover Media infotainment systems (Hugo_nz): Mk2 Tiguan VCDS Tweaks
    Always on rear brake light DRLs (NZ_GolfR): Mk2 Tiguan VCDS Tweaks
    Air-conditioning recirculation memory setting: Mk2 Tiguan VCDS Tweaks
    3rd rear brake light activation, Door mirror LED on with folding of mirrors, cornering fog light speed sensitivity: Mk2 Tiguan VCDS Tweaks
    Haldex AWD system adjustment: Mk2 Tiguan VCDS Tweaks
    Key Fob works when outside the car even whilst engine running (allows you to get the car running to precondition the interior and walk away with a locked vehicle): Mk2 Tiguan VCDS Tweaks
    Driving School Mode: Mk2 Tiguan VCDS Tweaks
    Deactivate the Prevention of cars overtaking on the Right (Tigger73): Mk2 Tiguan VCDS Tweaks
    - This tweak is helpful on the freeway when you are not in the right lane and approach a slower car driving in the right lane.
    Usually the car slows to the other cars speed (annoying if the car in the right lane travelling at 100km/hr in a 110km/hr zone) and does not proceed past them.
    Deactivating this setting allows you to continue at your predetermined cruise control speed and pass the car in the right hand lane.
    Reduce throttle tip-in delay and improve responsiveness:
    AutoInstruct's OBD11/VCDS tweaks:
    https://www.autoinstruct.com.au/manu...n-vcds-tweaks/
    Stemei.de coding: https://www.stemei.de/pages/coding/vw-tiguan-ii-ad.php
    Record of NZ_GolfR's tweaks:
    https://oncall-my.sharepoint.com/per...ding%20Changes
    Is anybody body as tmc and road sign recognition still working in 2018 models?
    Sent from my SM-G965F using Tapatalk
  6. #836
    Oct 2015
    Still works for 2018. Follow instructions and it’s very straightforward.
    I’ve done it on my car.
  7. #837
    Jun 2013
    Qld
    Quote Originally Posted by Simonr23 View Post
    I did but it's still not working TMC stays crossed.
    Also not really straightfords as instructions didn't explain how to activate missing RDS screen in Radio settings.
    But I will have another go at it.
    Thanks.
  8. #838
    Mar 2019
    Did you reboot the head unit?
    i got traffic sign recognition working tonight. It does come up with the error, but no ding which is good.
  9. #839
    Jun 2013
    Qld
    Which error exactly?
    Yes I did forced reboot. But nothing. And I got so many errrors. I had to clear all.
  10. #840
    Mar 2019
    don't remember the exact error, but it's a known issue. only comes up once a couple of minutes after starting the car, but the recognition seems to work OK. I only did it while waiting to pick up my better half at the train station, which is only about a 5 minute drive from home. Will report back after driving around more tomorrow.
