Page 82 of 118 FirstFirst ... 3272808182838492 ... LastLast
Results 811 to 820 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #811
    Quote Originally Posted by iDiesel View Post
    DLA - turns the lights in the direction of your steering wheel when cornering
    HBA - automatically turns on high beam, and dips it (or parts of it) when the camera picks up on coming cars
    Yes, this uses either the fog lights or a small light built into the headlights (depends on the model) to light up the side of the car approx 60 degrees off centre as you are cornering. The light comes on less than 30k/hr with indicator on
    Incorrect.
  2. #812
    Apr 2017
    It’s wrong.
  3. #813
    Dec 2010
    Helensburgh
    There is so much confusion on what is DLA it is understandable that some get it wrong and the Tiguan is especially confusing because there are two LED light assemblies that can be fitted. I think I may be correct in saying that DLA can differ even between cars such as a Golf and a Passat or a Tiguan.
  4. #814
    Aug 2018
    Quote Originally Posted by zzc2010 View Post
    It’s wrong.
    Still learning I guess
    I'll have another crack....
    HBA - simply turns High Beam off/on when it detects on-coming traffic
    DLA - high beams stay on (above 60km/hr ?) but mask around the oncoming car
    2018 Allspace 162TSI R Line
  5. #815
    Apr 2017
    Much more closer.
  6. #816
    Oct 2015
    From my reading (vw website info via googling)
    Hba is hi/Lo control only. With/without active cornering lamps (the ones that swivel) and with/without passive cornering lamps (the extra lights that just activate based on steering angle/blinkers/speed)
    Dla is that, but it has to have the added function of controlling high beam illumination via shutters and the headlight variable angle- on tigs at least.
    Some other vag products have multiple leds that can be individually operated to achieve a similar result- I guess that way allows more shapes and faster response.
  7. #817
    Feb 2019
    Perth, WA
    Quote Originally Posted by Ozsko View Post
    Agreed...
    Thanks to those who answered the question. I think I've got it now...
  8. #818
    Dec 2010
    Helensburgh
    Quote Originally Posted by Simonr23 View Post
    This is not available on earlier Tiguans and I don't know when the change took place but it must have been in the last 12 months.
  9. #819
    Oct 2015
    Don’t confuse not available with not enabled
    Us in little old Australia are a unique market. We disable perfectly fine features- yet leave them physically there, just to keep/make other models and brands their point of difference.
    I can’t recall which thread, or which page gives pictures to show the 2 light assemblies, but it is fairly straight forward to find out if your light assembly is dla capable.
    From there the tricky part is knowing which features to turn on/off with obd11/vcds- this hasn’t been fully researched to give definite answers of 2016 vs 2017 va 2018 cars and their software and ecm differences.
    If you just enable all the known options it often leads to errors. Not enough options does too.
  10. #820
    Aug 2018
    Page 60 of this very thread I think is what you are referring to
    Quote Originally Posted by PeteC View Post
    The three different headlights for Tiguans:
    L
