Page 80 of 118 FirstFirst ... 3070787980818290 ... LastLast
Results 791 to 800 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #791
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by daz32 View Post
    care to share the exact steps when you get a chance
    Just use the AS coding guide, see post 749. The critical part is resetting the lights and deleting errors.
  2. #792
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by Hole46 View Post
    Does yours have Module 4B or 55? I tried doing this one my a while ago but since it is one of the first models mine doesn’t have Module 4B only 55. I tried using the instructions for up to MY17 but couldn’t get it going. To be honest I didn’t try very hard.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #793
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by NZ_GolfR View Post
    Mine has module 4B.
  4. #794
    Nov 2016
    MAPLETON Qld
    Mine has module 4B.
    P.S. mine was built 1/12/2016, delivered Feb. 2017
  5. #795
    Mar 2019
    What is BCM on yours.
    If you have (09) BCM 1 1.0, them you won’t have separate headlight control module (55).
  6. #796
    Jun 2013
    Qld
    Quote Originally Posted by Ozsko View Post
    No, the earlier cars and I don't know when it changed had what might be called a dumb LED while at the same time production for cars in the UK for example had the active headlights and they are both different and distinctive headlight assemblies.
    Tiguan Owners manual - Google Drive
    Second last line second in from the right is the Tiguan electrical manual page 19.
    Mine is May 2018 build Comfortline and it definitely get DLA but not too sure if I really like it. Not really as bright as normal high beam.
    Just ordered an hex net dongle. Cannot wait to try it.
    I also have V6 Amarok highline but didn’t find lot of mods for them.
  7. #797
    Apr 2017
    Tried DLA on my loan Tiguan Allspace Comfortline with DAP.
    The DLA on Tiguan didn’t perform as well as my Passat. The headlight temperature was not as white (cool). Transitioning was not as smooth. It’s only on or off.
    Probably because Tiguan has one lens headlight but Passat has two lenses in its headlight unit.
    Passat DLA staging the high beams. The high beam slowly rises up to prevent sudden light condition changes. It’s way smoother.
    Also, I found Tiguan headlight can adjust the up and down way more than a Passat. Maybe due to the car is much higher.
  8. #798
    Oct 2015
    That wasn’t DLA. It was HBA.
  9. #799
    Apr 2017
    Quote Originally Posted by Simonr23 View Post
    Nah. It’s DLA.
    It blocked the front car from dazzled.
    I totally understand what’s High bean assist and Dynamic light assist man.
    https://1drv.ms/v/s!ApV1_q508oUGriuGdJvYd0GcZU_m
    That’s the headlight initiating.
    I suspect the NAR restrictions in AUS limited the DLA as well.
    The movement angles were not large.
  10. #800
    Oct 2015
    Ok, I stand corrected the wording off ‘on or off’ threw me.
