Page 77 of 118 FirstFirst ... 2767757677787987 ... LastLast
Results 761 to 770 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #761
    Nov 2013
    AUS
    Quote Originally Posted by Ozsko View Post
    Reading the PDF I linked to what light assemblies has your car got?
    It is the one that DLA is capable of.
    Don't know why it doesn't work for me but I have tried it a good 3 times now so I feel that it isn't worth wasting any more time trying to get it to work.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  2. #762
    Oct 2015
    Is there a way to raise/remove to 100kmh cutoff for ‘full’ highbeam being disabled with DLA?
    While I understand the reason for it, it’s counter-intuitive for the majority of roads in aus (100-110kmh but dual direction)
  3. #763
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by veew View Post
    Tried mine again this morning, got as far as A5 coding, byte 21, bits 5-7, code to 40, OBD11 wouldn’t let me change.
    Strange, first time I tried to code DLA, did this no problems, only stuffed up when I tried basic settings for headlights.
  4. #764
    Sep 2011
    Melbourne, Victoria
    I have an OBD11 arriving by the end of the week. Can it be used in 2 Tiguans or will it be locked out to just 1?
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  5. #765
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by INASNT View Post
    I am pretty sure you can use it on as many cars as you want. I’ve used mine on about 4 different cars so far without any issues.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  6. #766
    Sep 2018
    New Jersey USA
    You shouldn’t have any problems.
  7. #767
    Aug 2018
    Vic
    Quote Originally Posted by Simonr23 View Post
    What’s this? Is there a limitation in the DLA?
  8. #768
    Oct 2015
    It’s by design. The right hand high beam is disabled in auto mode, once you’re doing over 100kmh (speedo measured, not gps)
    It’s meant to give you better light on motorways, where there is a barrier on the right, so no ‘need’ of extra vision. Yet you can still have the left side lit up, increasing vision.
    Problem for me is it just looks jarring and makes the right side pitch black, as my eyes have adapted to the bright left side. Making the right side worse, than if I was on low beam all round.
    Also there are stuff all motorways in SA, yet millions of 100-110kmh roads that are one lane in each direction.
  9. #769
    Nov 2016
    MAPLETON Qld
    Just use normal high beam then.
  10. #770
    Oct 2015
    That reply isn’t really an answer to the question though, is it?
