Page 75 of 118 FirstFirst ... 2565737475767785 ... LastLast
Results 741 to 750 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #741
    Sep 2011
    Melbourne, Victoria
    Ecu + DSG tunes takes care of the sloop fly by wire throttle response even more.
    MY MK6 R throttle response was really bad, especially when trying to overtake in a high gear, would have to nearly floor it for the transmission to kick down a few gears.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  2. #742
    Dec 2017
    Castle Hill, NSW
    I made the Direct Acceleration change yesterday and it does feel different, especially driving around in the Hills District where it typically finds itself in the wrong gear moving through the side streets. I like it!
  3. #743
    Nov 2016
    MAPLETON Qld
    Can anyone tell me what bits are supposed to be on in Module 4B, Byte 10. I’ve been trying to to activate DLA by OBD11, but have had a few problems.
  4. #744
    Dec 2018
    Largs Bay, Adelaide
    Quote Originally Posted by Hole46 View Post
    Are you using this guide?
    Activate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding
    i picked up my wolfsburg yesterday and with less 60kms on the clock I coded DLA and TMC without issue
  5. #745
    Jan 2019
    NSW
    Nice, would prob consider this down the track. I'm super new to the VW coding game, but have experience working with Carly for BMW.
    Couple of questions:
    1) Is it a fairly involved job or is it a matter of buying the OBD11, and selecting the mods via an app? Or do you have to manually add coding lines to this?
    2) Does the Traffic monitoring appear in the heads up display as well? Or just in the AID?
    Thanks!
    Quote Originally Posted by jdstephens View Post
  6. #746
    Nov 2016
    MAPLETON Qld
    Yes I am using this. Been having problems including low battery so I tried reversing all the changes and reinstalling. I don’t know if I accidentally activated or deactivated some bits in module 4B, byte 10, so if someone could please tell me what the standard settings are?
  7. #747
    Dec 2018
    Largs Bay, Adelaide
    if your using an OBDEleven, then email your self the log or history and it will have the old values before you changed it in there.
    This is the long coding from mine before I changed it:
    000000050900084E07000F010A000000000000000000000000 0000000000
  8. #748
    Dec 2018
    Largs Bay, Adelaide
    Quote Originally Posted by GreyGoose_X View Post
    Thanks!
    i used the OBDELEVEN for the first time last night, didn’t even read the instructions or read the OBDEleven forums just figured it all out myself using the link above. So I don’t think it’s difficult but my only advice is to do one thing at a time.
    No the TMC doesn’t appear in the HUD, and I wonder if the satnav uses it to calculate the quickest route, I need to test this more. If I click traffic it will display all the messages for my route but I don’t think it incorporates it into the route planning.
    TBH I’m finding the HUD a real let down, at 110km/h the pop up glass vibrates a little which is distracting at night. The lack of info on it is bad as well. I would say it’s slightly better than not having one, but coming from a Beamer that had an excellent HUD it will take a bit getting use too!
  9. #749
    Nov 2016
    MAPLETON Qld
    I have the long coding in history, it’s the actual bits in byte 10 which are ticked or not that I require.
  10. #750
    Dec 2018
    Largs Bay, Adelaide
    you should be able to tick the bits until matches the code above, make sure you have the long code selected so you can see it change when you tick it or un tick the boxes.
    i probably need to read up on if it’s possible to restore the original, or perhaps save the original code so I can recall it if I need too.
