Page 71 of 118 FirstFirst ... 2161697071727381 ... LastLast
Results 701 to 710 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #701
    Mar 2017
    Quote Originally Posted by veew View Post
    Did you try doing the following?
    Attachment 42844
    Hi veew,
    I did but I wasn't sure how to do basic setting before.
    Anyhow, I've finally worked it out and I'm happy to report that I have successfully coded and tested it. It works beautifully and it is pretty obvious when you see it in action. I got so excited I turn my car around to test it again.
    Here is what I did. Follow below link, page1 and half of page2
    Activate Dynamic Light Assist (DLA) - from MY 2017 - AS.Coding
    After the first 4B coding (top half of page 2), you should get an error (lights pointing to the ground). Do as the document says to perform basic setting and the error will go away and the light will readjust and go back to normal. Now clear the error on 4B.
    We are nearly there but not quite. Now check the car Menu, lights and make sure Dynamic light assist is tick and push the light stalk forward. You should see the light with an A inside on the AID (exactly the same as light assist) but you should get another error at the same time. If you don't then you may be set to rock n roll.
    So if you do get the error like me, refer to the bottom half of page 2. My advice is don't do all the 4 codings in one go, do one at a time. After each one, perform basic settings and clear error. You may not need them all. For my car, I only needed to do the second line and the error goes away and it works.
    I hope this is helpful and good luck.
  2. #702
    Dec 2010
    Helensburgh
    Quote Originally Posted by Steve2010 View Post
    Hi bushpig667 just to let you know the DLA works a treat! Tried them tonight and boy do they work well! Thanks again bushpig667 for your help on this. Greatly appreciated. Owe you one!
    Steve, referring to post 213 which headlights has your car got and what year model is it.
  3. #703
    Dec 2018
    Largs Bay, Adelaide
    Quote Originally Posted by MikeyT View Post
    Hi veew,
    Good work and thanks! Are you able to provide a video demonstrating it working?
  4. #704
    Mar 2017
    Quote Originally Posted by jdstephens View Post
    Here you go. Not a very good video but you can see that it's masking the bright road signs, on coming cars on the right and it also created a U shape when there are cars in front of me.
    I did not get any beep from on coming cars so I guess it's working well.
  5. #705
    Dec 2018
    Largs Bay, Adelaide
    Excellent work and thanks heaps for this!! Just boggles my mind why VW have this turned off in Australia when the cars here have all the hardware.
  6. #706
    Mar 2013
    Brisvagas
    A bit annoyed after jumping in the car this morning to do a little coding.
    It seems that my Tiggy isn't supported by the HEX+CAN cable.
    So now to choose between another Ross-Tech product or an OBD11.
  7. #707
    Dec 2018
    AU
    Quote Originally Posted by Psych101 View Post
    Does this work on a mk2 tiguan?
    Tried this today. Was not expecting it to work given the change is in the steering assist module but it actually makes a noticeable difference to throttle response.
    I actually coded via a carista app but checked in obdeleven and carista just changes the same setting.
    Highly recommended.
    Sent from my SM-G955F using Tapatalk
  8. #708
    Nov 2013
    AUS
    Highly recommended.
    Would you be able to describe in more detail what changes it makes to throttle response? Just so I can describe the relevant changes in the original post with link.
    Also for those not sure what Psych101 is referring to: Mk2 Tiguan VCDS Tweaks
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  9. #709
    Dec 2018
    AU
    Also for those not sure what Psych101 is referring to: Mk2 Tiguan VCDS Tweaks - Page 68
    Sensitivity of throttle increased and reduced delay between accelerator pedal input and engine response
  10. #710
    Dec 2018
    AU
    Hi veew,
    Do you need or does this work in combination with the steps to activate high beam assist?
