Page 68 of 118 FirstFirst ... 1858666768697078 ... LastLast
Results 671 to 680 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #671
    Jan 2019
    Perth
    Hi greygoose_x. My DLA works a Treat. I have video but can't upload to this thread. Can someone assist? I'm happy to email the vid. Looks great and you can see it clearly in action.
  2. #672
    Quote Originally Posted by Steve2010 View Post
    Upload to YouTube then you can link it from there.
    Dec 2017
    Castle Hill, NSW
    Has anyone discovered a way to change the Max KW on the "Sport" screen yet? Mine is stopping at 162 kw, but since the same unit is used on the Golf R there must be some way to change it.
    Thanks
  4. #674
    Dec 2018
    AU
    Can throttle response be adjusted with obdeleven and does anyone have a link to instructions?
  5. #675
    Dec 2018
    AU
    Quote Originally Posted by Psych101 View Post
    Does this work on a mk2 tiguan?
  6. #676
    Jan 2019
    NSW
    Yep, upload to Youtube, and post the video link here!
  7. #677
    Dec 2018
    AU
    I tried using the app in obdeleven to activate traffic sign recognition but it doesn't seem to be working on my MY19 wolfsburg. Has anyone else got this working via the app?
    If I want to do the long coding method should I undo the app version first? 100 credits to undo something that doesn't work is a bit unfair
  8. #678
    Jan 2019
    Melbourne,Vic
    I had the same problem but got it working, the app did most of the job so don't undo it.
    There was one more setting that required changing:
    Control unit A5
    Adaptation
    Road Sign Detection Fusion Mode
    Change to ‘Road Sign Detection’
    Reboot the Infotainment unit
    And then in the infotainment Vehicle settings, Driver assistance settings there is an option to show in instrument cluster which displays it on the Virtual cockpit, but this setting keeps disabling for me for some reason and I need to re-enable it.
  9. #679
    Dec 2018
    AU
    Quote Originally Posted by impsta View Post
    Control unit A5
    Adaptation
    Cheers. Will give it a go later today.
    Annoying you to have to re-enable and hope there is a fix for that too
  10. #680
    Dec 2018
    AU
    Control unit A5
    Adaptation
    Followed your advice but had to do the changes in control units A5 and 17 below as well. Works properly now and stays on unless I switch it off (don't have to re-enable).
    Recommend checking every step below has been done in yours to see if this solve the issue of having to re-enable on start-up.
