Page 66 of 118 FirstFirst ... 1656646566676876116 ... LastLast
Results 651 to 660 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #651
    Jan 2019
    Perth
    Hi bushpig667, can you supply me with your long coding on 4b please. I've tried to clear my error message for the song of the DLA but I keep getting an error message saying, cornering light (afs), with the orange exclamation mark on the dash. Have tried everything as stated above but no luck. Followed the instructions correctly except at front sensor a5 coding. It is a bit different but I've set byte 19 to 30. The rest is identical. Tried resetting many times but no go. Any help would be appreciated.
  2. #652
    Jan 2018
    Auckland, NZ
    Quote Originally Posted by Steve2010 View Post
    A5
    000307060000010100022346C156A90098000E300040
    4B
    000000050100085207104F010A000000000000000000000000 0000000000
    For my car, after I had completed the coding, changing byte 9 to 10 in module 4B cleared my AFS fault.
    Hope that helps.
  3. #653
    Jan 2019
    Perth
    Thanks mate I'll give that a try. Just out at the moment but heading home shortly. I'll try and let you know.
  4. #654
    Jan 2019
    Perth
    Thanks bushpig667. Problem solved and fixed. The important part was changing byte 9 and 19 to 10 after all the coding is done. Took the fault away instantly. Now to try the lights at dark. Still daylight here in Western Australia!
  5. #655
    Jan 2019
    Perth
    Hi all does anyone know how to keep adaptive Lane guidance on permanently? Mine keeps unticking itself every time I turn the car off and on. Very annoying?
  6. #656
    Make sure to set Bit 3 in Byte 14 of A5 front assist camera.
  7. #657
    Jan 2019
    Perth
    Hi bushpig667 just to let you know the DLA works a treat! Tried them tonight and boy do they work well! Thanks again bushpig667 for your help on this. Greatly appreciated. Owe you one!
  8. #658
    Jan 2019
    Perth
    Thanks kamold. I'll try this in the morning and let you know how I go.
  9. #659
    Jan 2019
    NSW
    Nice work! Any chance of posting a video with the DLA in action?
  10. #660
    Jan 2018
    Auckland, NZ
    Quote Originally Posted by GreyGoose_X View Post
    I tried to do a couple videos but unfortunately my cameraman skills are weak and it’s just a blurry mess. Maybe steve2010 can do better!
