Page 59 of 118 FirstFirst ... 949575859606169109 ... LastLast
Results 581 to 590 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #581
    Aug 2018
    Vic
    I have an Allspace. I coded it manually using OBD11 as per the guide on the auto instruct website.
  2. #582
    Quote Originally Posted by Clarkie View Post
    Have you gone into the Vehicle Settings, then Instrument Cluster and turned on ‘Dynamic Road Sign Display’?
    Mine works great. I do get a quick message in the AID that says ‘Dynamic Road Sign Display is currently restricted’. Not sure this is normal or not.
    We will always get that until VW releases a map that says we are allowed to have the feature. It's not officially supported here.
  3. #583
    Apr 2017
    The 2019 Toureg is not going to support TSR. No maps anytime soon. So SAD Mk2 Tiguan VCDS Tweaks
  4. #584
    Dec 2018
    Perth
    I have tiguan my19 so my only assumption they changed something between my17/18 to my19 models. Anyways going to try it now again and go for a drive. Fingers crossed
  5. #585
    Aug 2018
    Vic
    Ah ok, good to know it’s expected. Only flashes up quickly so no big dramas.
  6. #586
    Oct 2015
    having a play with my new obd11 and there looks to be an option to disable the warning message for traffic sign recognition. im pretty sure it was in the same area as where you choose fusion/read only(i forget the terminology sorry) i didnt change it from active to inactive, as i just wanted to follow existing instructions, but interesting...
  7. #587
    Oct 2015
    Is it possible to have the speed limit option work in Australia? I enabled two functions within the speed sign detection area, that would be good to have, but when I try to select them from the touchscreen, they say not available.
    Otherwise I enabled pretty much all the turned off features and a couple of others.
  8. #588
    Dec 2018
    Largs Bay, Adelaide
    The Tiguan Wolfsburg has listed in its specs “dynamic cornering lights” but dynamic light assist is not listed. Does the Wolfsburg have the hardware required? I ask because Ive read through the electrical service manual and it describes the two different LED light assembly’s. Basic LED and MID LED. The description for MID lists both ‘dynamic cornering lights’ and ‘dynamic light assist’ whereas the description for the Basic LED doesn’t.
    i took a Wolfsburg for a test drive yesterday and dynamic light assist wasn’t an option in the settings so wonder if this can be coded?
    If the hardware is there but not turned on I find that strange and a poor descision
  9. #589
    Oct 2015
    Mk2 Tiguan VCDS Tweaks-img_8674-jpgMk2 Tiguan VCDS Tweaks-img_8675-jpg
    these lights are the type that allow dynamic cornering (its the little light on the inside of each housing that points outwards, that allows this) and 'beam shaping' (whatever the correct term is) on high beam. although i fear ive managed to disable the beam-forming side of things in my obd11 playing around, as last night it was purely auto hi/lo selection- but this was in heavy traffic.
  10. #590
    Dec 2018
    Largs Bay, Adelaide
    Quote Originally Posted by Simonr23 View Post
    Is that a Wolfsburg? And have you seen the beam shaping work after coding or was last night the first time you tried?
