Page 54 of 118 FirstFirst ... 444525354555664104 ... LastLast
Results 531 to 540 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #531
    Oct 2018
    Hey guys, got my Tiggy (Comfortline, with Driver Assist and Lux packages), and looking to make a few tweaks to it. My wishlist includes:
    1. Traffic Alerts
    2. Speed Limit on dashboard instrument (active info display) - is this actually possible?
    3. TJA
    4. Changing which lights work for DRL
    I'm not sure if I should be looking at getting an OBDeleven or whether I can pay someone to do this for me given it looks to be a once off (and I don't have an android). Any thoughts on where I could do this? I'm based in the inner-north of Melbourne.
    D
  2. #532
    Nov 2018
    Gaurain Ramecroix
    Hello ,
    For anyone he is interested to activating Trailer Assist, you have coding here (OBDeleven).
    Mk2 Tiguan VCDS Tweaks-trailer-assist-png
  3. #533
    Nov 2018
    Gaurain Ramecroix
    Hello,
    Does anyone know the coding(OBDeleven) for steering wheel heating? Thank you
  4. #534
    Sep 2018
    New Jersey USA
    Quote Originally Posted by adysh View Post
    Hello,
    What do you want to do? I made changes to mine with their apps
  5. #535
    Nov 2018
    Gaurain Ramecroix
    I want to know what coding must to do , for activated the heating in steering wheel .I maked something, but it's not right.How did you do the coding?
  6. #536
    Oct 2018
    Melbourne, VIC
    Doesn't seem like this question has been asked, but apologies if it has:
    With activating Traffic Sign Recognition, does this information feed into the ACC? ie if i'm cruising along with ACC set to 80 km/h and it picks up a sign saying the limit is 100km/h, would it automatically register that speed, and increase the car's speed to 100?
    Or is it merely a tool for monitoring the posted speed limits?
  7. #537
    Jan 2018
    Ireland
    Quote Originally Posted by PDMJO View Post
    It’s just monitoring and displaying the detected speed limit on the dashboard.
    Sent from my iPhone using Tapatalk Pro
  8. #538
    Oct 2018
    Melbourne, VIC
    Quote Originally Posted by NZ_GolfR View Post
    Also if anyone is interested I found that if you have electronic seats you can turn on the Easy Entry/Easy Exit function:
    Seat Adjustment Driver Side (36) - Coding - Easy_Entry_front - Change to Active
    This will slide the seat all the way back when you turn the car off to allow you to get it out and then when you get back in and turn the car on it slides forward to the saved position.
    I've activated the Easy Entry/Exit function, however, it only slides the seat back for about a second, then stops. Any of you have a clue as to what might be going wrong?
  9. #539
    Nov 2018
    taiwan
    Long coding
    Control unit: 6C Camera System Rear View
    I can't find 3D_Presentation after entering long code
    I use VCDS
  10. #540
    Nov 2018
    taiwan
    Long coding
    I use VCDS
