Page 52 of 118 FirstFirst ... 242505152535462102 ... LastLast
Results 511 to 520 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #511
    Jun 2018
    Bogota Colombia
    Is there any option to get the off road and performance screen. I have being googleing but without any luck
    Sent from my SM-G9650 using Tapatalk
  2. #512
    Aug 2017
    Uk
    Quote Originally Posted by JRTiguanCol View Post
    some cars you can enable off road but performance monitor is a SWaP function
  3. #513
    May 2017
    Quote Originally Posted by Jap View Post
    its in long coding, it’s part of the ACC, if you have the cruise set and your on a dual carriageway on the inside lane and coming up on a car in the right lane then the car slows to the speed of the car in the right lane, the mod stops you slowing allowing undertaking, it was discussed on the Passat/arteon forum a while back
    I'm not sure about MY18s but my MY17 Tiguan don't have this problem. Make sure you have it before start fiddling with it.
    I had this problem and deactivated it on my MY18.5 Golf so I know how annoying it is and I'm certain MY17 Tiguan does not come with this function preprogrammed.
  4. #514
    Jan 2018
    Ireland
    I checked and I've this option disabled by default. Quick one for you - does the other lane appear on the AID only when this feature is turned on?
  5. #515
    Feb 2015
    WV, USA
    My Tiguan has third row seats and consequently the tailgate can only be opened but not closed with the remote or the door switch. I would like to change this so that I can both open and close the tailgate remotely.
    I have VCDS. Does anyone know what parameters need to be changed in order to enable this?
  6. #516
    Oct 2016
    Just as an experiment, try closing the tailgate from inside with the engine running. My Audi, a current model A6 Allroad, works this way.
    I don’t know the logic behind it. I can open the tailgate with the inside button regardless of the engine running or not, but can only close it from inside with the engine running.
  7. #517
    Feb 2015
    WV, USA
    I tried the experiment and it did not work.
    Quote Originally Posted by IsDon View Post
  8. #518
    OBDeleven - Novice - Help!
    Hi
    I recently purchased OBDEleven Pro from autoinstruct. I own a 2018 Mk2 Tiguan and thought to customise some settings. I was trying to turn off start/stop, enable high beam assist, and traffic management on the navigation.
    Unfortunately, I have made a mistake and can’t remember what I changed. There is now an error “error cornering light (AFS)”
    Seeking the community’s help and expertise on how to fix this?
  9. #519
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by Melbourne_Tiggy View Post
    Hi
    In the OBDEleven app you can view your history which will show you all the changes you have made. From there you should be able to either work out where you have gone wrong or you can manually go through and undo all the changes you made.
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  10. #520
    Feb 2018
    France
    Quote Originally Posted by NZ_GolfR View Post
    In the App, go to : Garage -> your car -> History
    And you can see all your changes.
