Page 48 of 118 FirstFirst ... 3846474849505898 ... LastLast
Results 471 to 480 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #471
    Dec 2017
    All, can the OBD11/VCDS be used to reprgramme the service date? See below for reason for asking.
    If so is there anyone in the Elsternwick/Caulfield area that could assist?
    My MY17 Tiguan is telling me that it's due for its 1st oil service and inspection. May 5th being the date programmed into the ECU etc. However I didn't buy it and take delivery until Nov 29 last year (hence the good deal I got). I took it to a dealer (not the selling dealer) for the first service but they didn't service it due to the fact it's only done ~4950km. They said it's due on Nov 29 or at 15000km - fair enough.
    They also said they couldn't reset the service warning as that would add 365 days and 15000kms to the current settings meaning that it's be out of kilter with respect to it's programmed dates.
  2. #472
    Last weekend I helped another forum member add a few extra options to their gen2 Tig:
    • Needle sweep
    • Enable Mirror / Puddle Lights When Mirrors Are Closed
    • Anti-Theft Horn
    • Auto Close Windows When Raining
    • Tap to Indicate – Number of Blinks
    For those looking to get the Anti-theft alarm working (horn sounds when door is opened when “armed”), here's the settings:
    Select Control unit 09 (Central Electrics)
    Security Access code 31347
    THEN 10-ADAPTATİON
    To make things easier search for "Anti-theft" and set the following:
    • Anti-theft device-Anti-theft Alarm System = Active
    • Anti-theft device-DWA Alarmverzoegerung = driver door contact thatcham
    • Anti-theft device-DWA Camper Modus = ACTIVE
    • Anti-theft device-DWA_Einfachhorn_oder_Sounder = Horn_verbaut
    • Anti-theft device-Ueberwachung Innenentriegelungshebel = ACTIVE
    • Anti-theft device-Akustischer Alarm Signalhorn = ACTIVE
    Next search for "acknow"
    • Acknowledgement signals-Akustische Rueckmeldung global = ACTIVE
    • Acknowledgement signals-Akustische Rueckmeldung signalhorn = ACTIVE
    May 2018
    Any option for extending the time between when the car requires to you hold the wheel when using active lane guidance? It’s set at 14 seconds.
    Tiguan 162tsi Sportline
  4. #474
    Mar 2017
    • Needle sweep
    • Anti-Theft Horn
    Hi tigger73,
    Did you use OBD11? Can you share the settings you use to get the "Auto Close window when rain" working? Thanks.
  5. #475
    Dec 2017
    Quote Originally Posted by Janus77 View Post
    The warning comes up at around 12 seconds, the beep at around 14 seconds. However I always push it to the next and final warning BEEP which gives you an "additional" 20-23 seconds (total 30-33 seconds). BUT BEWARE, after the last long Beep you only have 2-3 seconds to take action AND move on the steering wheel otherwise the auto brake will activate and that gives you and all passengers a frightening experience they wont forget.
  6. #476
    Quote Originally Posted by MikeyT View Post
    Hi tigger73,
    VCDS and this one I don’t think is working yet. There’s either a setting we’re missing or in car setup is not right.
    Ardil may be able to shed some more light on what we’ve tried.
    Apr 2018
    Taiwan
    I have seen more than 10 colours to select as shown above. Is there anyone know the setting/codes in obd11? Appreciated in advance.
    從我的iPhone使用Tapatalk Pro 發送
  8. #478
    Dec 2017
    Hi tigger73,
    I have tried resetting the required factory settings as described in the threads however its a no goer for me on this one. Maybe someone will come up with a fix for it for those of us who havent been able to get it working.
  9. #479
    Aug 2017
    Uk
    Is your sensor in the windscreen 2 or 4? As 2 it won’t work on, only 4
    2
  10. #480
    Dec 2017
    I can only see a windscreen photo of 2, but this is mineMk2 Tiguan VCDS Tweaks-frontwindow-jpg...
