Page 44 of 118 FirstFirst ... 3442434445465494 ... LastLast
Results 431 to 440 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #431
    Jul 2010
    Have tried a few of the tweaks here, thanks to all for researching and sharing. Used VCDS to change everything. My thoughts/results:
    Traffic Reports/TMC
    - Couldn't get it to work. Might have done something wrong in my setup, had a few goes but no results. Used 1024 and another setting I found on OzAudi, both no go so far. Mine is a late 17 build with the newer head unit, so maybe something is different.
    Traffic Sign Recognition
    - Works well, quite handy. Going to keep it on. A little fiddly to setup though. Don't know why it's not enabled on the Oz delivered cars.
    Disable start/stop
    - Works! Great
    Haldex AWD setting
    - Changed to the increased traction setting. Massive difference! Feels like a different car. Now drives something like I want it to, can notice the extra drive from the rear. It reminds me of the Q5 I drove in terms of feel on the road. Will leave it for a while and see what happens, if no noticeable downsides I'm tempted to leave this setting on permanently.
    Sent from my SM-G955F using Tapatalk
  2. #432
    Apr 2017
    Quote Originally Posted by Dan_3MPS View Post
    Traffic Reports/TMC
    Disable start/stop
    - Works! Great
    Haldex AWD setting
    You don't have the error from TSR?
  3. #433
    Jul 2010
    Quote Originally Posted by zzc2010 View Post
    Only when it can't find a sign in the first few minutes after starting up, goes away after a few seconds. As soon as it sees a speed sign it's all good. Even picked up the random 10km/h sign in the supermarket car park tonight.
    Edit: I set it to 'detection' rather than 'fusion'
  4. #434
    Apr 2017
    Ya I know.
    Same.
  5. #435
    Feb 2018
    Kellyville
    Anybody available for some coding around Norwest/Kellyville. Looking to get the TMC and sign reading (anything worthwhile too). Case of beer on the cards. Thanks
  6. #436
    Quote Originally Posted by SmokinAce81 View Post
    I can help you out.
  7. #437
    Feb 2018
    Kellyville
    Messaged you, thanks Champ
  8. #438
    Dec 2017
    Hi all, I had trouble getting any more than 3 flashes of the convenience turn signal... here is the solution:
    Performed on OBDeleven
    Convenience turn signal:
    Central electrics 09
    Adaptation
    Aussenlicht_Blinker
    Komfortblinken Blinkzyklen (value 0-5)
    APPLY
    (On car centre console) MENU
    Vehicle
    Settings
    Factory settings
    Reset individual settings - Light
    Back
    Light
    Convenience turn signal (un-check/check)
    Ta Da
  9. #439
    Jul 2017
    Toowoomba Qld
    Hi,
    Is anyone available to carryout some coding around Toowoomba/Brisbane area looking for the start/stop deactivation, start up warning, tmc, auto highbeam and any other worth while codes.
    I have a 2017 162tsi.
    cheers
  10. #440
    Oct 2017
    Copenhagen, Denmark
    Traffic Reports/TMC
    Disable start/stop
    - Works! Great
    Haldex AWD setting
    Which method did you use to disable start/stop?
    VW Passat Variant Highline B8 2017
    VW up! Move up! 2014.
