Page 42 of 118 FirstFirst ... 3240414243445292 ... LastLast
Results 411 to 420 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #411
    Dec 2010
    Helensburgh
    Quote Originally Posted by bigkyle View Post
    Also, I would guess the answer would be yes, but does anyone know if enabling TJA (for example) voids the cars warranty?
    No comment from the dealer when my car was serviced after TJA had been activated.
  2. #412
    Feb 2018
    France
    Sorry if this has been covered (I have looked but couldn't find anything), I've just bought the OBDEleven Pro, but I'm worried about "bricking" my car. I would only be following the commands that have been posted here, and I obviously wouldn't go changing random codes that I'm not sure about, but I am wondering how smart the car is, as in would it not allow you to make any changes that would prevent the car from starting? Is it possible to "reset to factory default" if needed?
    I think there is no many dealers who understand something in electronic.... I talk about France in my case....
  3. #413
    Aug 2017
    Uk
    dealers don’t know or seem to care what’s enabled from the factory or by others, I’ve heard of others taking their car into vw to get stuff sorted that they accidentally disabled, and have had success getting it sorted
  4. #414
    Dec 2010
    Helensburgh
    In a discussion today with one of our forum members I mentioned that I had read this...
    Drivers Reaction Adjustment (Car must be fitted with Camera)
    Adjusts the sensitivity in which the car will alert the driver due to lack of steering input.
    Select Control unit A5 (camera)
    Security access
    Enter unlock code 20103
    Adaptation
    Select channel deactivation threshold driver activity
    Value adjust accordingly Default: medium options: early, middle, late
    Taken from here....
    https://www.autoinstruct.com.au/manufacturer/volkswagen/mk2-tiguan/mk2-tiguan-obdeleven-vcds-tweaks/
    Now I have re-read it I am not sure if I interpreted it correctly, does this refer to the weight that must be applied to the steering wheel and torque sensor in the rack or to the time interval that the steering input must be made.
  5. #415
    Feb 2018
    France
    Quote Originally Posted by Ozsko View Post
    Security access
    Adaptation
    Taken from here....
    It's the time interval that the steering input must be made.
  6. #416
    Dec 2010
    Helensburgh
    Quote Originally Posted by nowmax View Post
    What difference in time is there from early to late?
  7. #417
    Dec 2017
    Castle Hill, NSW
    Hi all,
    I'm attempting to enable rear fog lights for my highline. Has anyone had any luck with this? I looked at the Golf tweaks but they don't seem to match what I'm seeing.
  8. #418
    Lightbulb
    Kyle: The short answer is that it is entirely possible to "brick" the car to the extent that it needs to be taken back to a dealer.
    For example, I have never been "brave enough" to run a simple output test on the Airbag control module (@ address hex03) using any diagnostic device that I own (i.e. VCDS, OBD11, or VCP). As one of the cable manufacturer describes:
    " it won't deploy your airbags. But it MAY render the vehicle undrivable. Running Output Tests is supposed to make the airbag controller generate a simulated crash signal to the rest of the systems in the vehicle so that unlocks itself and shuts various things OFF.
    Unfortunately, one of the things it shuts off is the power supply to at least the Engine Control Module, and possibly to other modules (I'm guessing). I suspect that resetting the car, so that it is drivable isn't just a case of clearing the Trouble Code.
    But, this is an extreme example, and more likely, the type of problem that will be encountered is less severe. Generally, an unintentional, aberrant code change will result in an error message on the car's screen, or a more innocent Trouble Code on your OBD11 software. These type of errors are more-fixable by the user.
    Alas, there is no "reset back to factory setting" on any diagnostic device that I'm aware-of. What happens when you make a change to either an adaptation channel, or to a Byte/Bit in the module's coding is that the new value over-writes the old value and the old value is lost forever. But ALL devices have a kind-of "remedial" facility to help the user back-track his/her steps. In OBD11, the function is called "History". The history report reveals the before/after values of every change that you make with your device. Here's a example of the type of information that is in the history report:
    first, for a change to an adaptation channel:
    Adaptation
    Control unit: 09 Central Electrics
    Values:
    Dimmwert EF 20:
    Old value: 0
    New value: 20
    Mileage: 3949 km
    Date: 2017-11-16 16:53
    Second for a change to a module code -string:
    Long coding
    Control unit: 55 Headlight Regulation
    Old value:
    021801010B000400
    New value:
    021801003F000400
    Mileage: 2473 km
    Date: 2017-09-21 14:52
    Notice the Old/New value entries. But to revert these values, you will need to manually make the change with your OBD11 device.
    But, if I can provide one piece of advice for any new user of a diagnostic device, it would be to try and make a least a few errors in your learning experience. These events will invariably be your most useful learning tool
  9. #419
    Nov 2013
    AUS
    Quote Originally Posted by veew View Post
    Saw this tweak in the Golf VCDS thread, "Enabling key FOB whilst engine is running":
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    Let me know if anyone gets this working, I will get around to it eventually so will report back then.
    No luck getting it working for me. If anyone does get it working, let me know!
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  10. #420
    veew: Byte 4, Bit 2???? This is the "carsharing" software switch :
    Have you tried setting the BCM adaptation channel ENG10579-ENG115754-ZV allgemein-Funk bei Klemme 15 ein to active ?
