Page 35 of 118 FirstFirst ... 2533343536374585 ... LastLast
Results 341 to 350 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #341
    Oct 2017
    Copenhagen, Denmark
    Quote Originally Posted by artful View Post
    Change the binary to 00000101 at byte17
    Thanks. Just tried it, though it did something else; The settings menu (text) changed from being originally justified to the left to being justified to the right.. The above skin option you have now never changed from the original horisontal linear style to your grid layout style, sadly. I have a Passat B8 Discover Pro from 2017.
    VW Passat Variant Highline B8 2017
    VW up! Move up! 2014.
  2. #342
    May 2017
    Sweden
    Does anybody know if it is possible to code foglights on with drl? (I want the foglights to be on, when the headlights are off)
    Skickat från min SM-G950F via Tapatalk
  3. #343
    ^^^ try this:
    Left-side fog light: ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 > change from not active to Tagfahrlicht
    right-side fog light: ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 > change from not active to Tagfahrlicht
    EDIT: Ooops- I think that the latest version of VCDS (which you should be using on your Tiggy) has the Leuchte-commands translated into English. If you can't find "Tagfahrlicht" in the settings, select "Daytime Running Light"
  4. #344
    May 2017
    Sweden
    ^^^ try this:
    Thank You very much!
  5. #345
    Nov 2013
    AUS
    FYI, there is now a dedicated Mk2 Tiguan OBD11 tweak page on AutoInstruct:
    Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
    Also there are some modules I can't access (Reverse camera and A5) for adaptations or long coding. Anyone else have this issue and is there a way fix it?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  6. #346
    Dec 2017
    Quote Originally Posted by veew View Post
    Cheers mate, looks like a One stop shop the place to go for all tweaks.
  7. #347
    Jan 2018
    Ireland
    Hi all! Thanks for sharing some amazing Tiguan mods!
    I’m wondering if anyone know how to turn off or modify warnings about AdBlue level in diesel engines? They appear as soon as you hit 2500km left on AdBlue tank and they are annoying as hell to see them every time I start the car.
  8. #348
    ^^^ hmm try this:
  9. #349
    Dec 2017
    Is this a suitable product for going down the obdeleven path?
    OBDeleven PRO Diagnostic System – Audi, Skoda & Volkswagen – AutoInstruct
  10. #350
    Nov 2013
    AUS
    Quote Originally Posted by ingy View Post
    Yeah thats the one
    Current:
