Page 31 of 118 FirstFirst ... 2129303132334181 ... LastLast
Results 301 to 310 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #301
    Quote Originally Posted by point View Post
    Just a thought - the US-spec Mk2 Tiguan remote start via the keyfob - is it possible that in *theory* this is just coded into the car with no additional hardware as it starts the engine when triple pressing the unlock button? if so it may be able to be coded in to a ROW spec Tiguan? and thus coded to my Golf 7.5
    Would love.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  2. #302
    Mar 2017
    Quote Originally Posted by veew View Post
    Just wanted to thank everyone who has contributed to this thread. I've activated the following thanks to many of you:
    - 3rd/High-Mounted Brake Light Tweaks
    - Avoid Dimming LED Lights when Indicating Golf Mk7
    - Automatic Window Closing in Rain
    - Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
    Great work veew, can you provide the settings for the above 4 settings?
    Also can you explain what this one does and whats the benefit of having it? and when will it switch off?
    - LED lights in door mirrors light, even in close
    Thanks.
  3. #303
    Nov 2013
    AUS
    Quote Originally Posted by MikeyT View Post
    Thanks.
    The LED lights in the underside of the mirrors are normally off while in the process of folding in and out. This tweak turns it on.
    Here is a video - YouTube
    3rd/High-Mounted Brake Light Tweaks - Instructions
    • Select 09 - Central Electr control module
    • Select Security Access - 16 from the "Open Controller" screen
    • Enter the magic number 31347 and return to the "Open Controller" screen
    • Select Adaptation - 10 from the "Open Controller" screen
    • From the pull-down button check that the default settings for the adaptation channels shown in the table below are as indicated in the Standard setting column
    • For the wanted options, change the adaptation channels depicted in the table below to the values in the appropriate column (tip: use the "Search" box to locate the channels)
    Mk2 Tiguan VCDS Tweaks-obd11-3rd-brake-light-jpg
    Avoid Dimming LED Headlight DRLs when Indicating Golf Mk7
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    (12)-Leuchte2SL VLB10-Lichtfunction E2
    Select: not active
    (12)-Leuchte3SL VRB21-Lichtfunction E3
    Select: not active
    The following changes removed the "wink" feature. Those that don't like the feature this is for you.
    • Golf Mk7 Disable Turn Signal Wink (alternative instructions)
      • Module 09 - Central Electronics
      • (-Leuchte3SL VRB21-Lichtfunktion C 3 Blinken rechts aktiv (beide Phasen) —> Not Active
      • (-Leuchte5 TFL RB32-Lichtfunktion C 5 Blinken rechts aktiv (beide Phasen) —> Not Active
      • (-Leuchte2SL VLB10-Lichtfunktion C 2 Blinken links aktiv (beide Phasen) —> Not Active
      • (-Leuchte4TFL LB4-Lichtfunktion C 4 Blinken links aktiv (beide Phasen) —> Not Active
    • Go into Module 09 Central Electronics
    • Go into Security, use 3134 as the security code.
    • Select Adaptations, and then ZV Komfort
    • Select Regenschliessen_ain_aus, toggle to Active. The default is "not active"
    • Then select Regenschliessen_art, toggle to Active. The default is "not active"
    • Finally select Menusteuerung Regenschliessen, toggle to Active. The default is "not active"
    • This enables Automatic closing in rain as a menu option under Window Operation
    Security access
    Security Code 31347
    Adaptation
    (3) Static cornering light lower speed threshold
    New Value=0
    (4) Static cornering light upper speed threshold
    New Value=50
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #304
    Mar 2017
    Thanks veew. Much appreciated.
  5. #305
    Nov 2013
    AUS
    Came across these new tweaks on AutoInstruct website:
    Haldex All-Wheel-Drive Adjust Traction
    Reports indicate that changing this setting to ‘Increased Traction’ improves the handling and makes the car feel like a permanent AWD system.
    Select AWD Control Unit
    Adaptation
    Logic
    Choose from ‘Standard, Increased Traction, Less Noise’
    Closing Windows When Ignition Off
    Allows you to operate all windows after the ignition has been switched off and doors opened.
    Security access
    Access Code 31347
    Adaptation
    (13) – Zugangskontrolle 2 released trailing FH cancel at Tueroeffnen
    Value = Aktif
    My friend currently has my OBD2 and tablet so won't get a chance to try it anytime soon.
    Current:
  6. #306
    Mar 2017
    Good day all, Has anyone successfully configured and tested the "Automatic Window Closing in Rain" feature?
    I've configured it but haven't had a chance to test it as no rain so far. However, I noticed that option for Auto window closing in the car menu automatically untick every time I restart the car. Does anyone who have this setting have the same issue?
  7. #307
    Apr 2017
    JHB, South Africa
    I have coded and tested and mine seems to be one of the cars that it just won't work on. I get the option in the menu as well and it remains ticked permanently. So not sure why yours resets when you start. I have recorded in different orders etc... But mine refuses to work.
  8. #308
    Nov 2013
    AUS
    Just tested my car. Didn't work regardless of whether the car was locked or unlocked.
    My setting in the options menu is ticked permanently as well. Pity
    Current:
  9. #309
    Mar 2017
    That's a bummer. I also just discover an issue with my bluetooth and wondering all this coding somehow stuffs it up. My Android phone keep dropping off bluetooth connection with the car every few mins. I can reconnect but it will just keep dropping. Anyone else have this issue or all iphone users in this forum?
  10. #310
    Nov 2013
    AUS
    It shouldn't effect the BT. What phone do you have? Might be the phone or firmware version? Have you tried hard resetting the phone?
    Current:
