Page 30 of 118 FirstFirst ... 2028293031324080 ... LastLast
Results 291 to 300 of 1176
Thread: Mk2 Tiguan VCDS Tweaks
  1. #291
    Aug 2017
    Uk
    Backup
    Control unit: 6C Camera System Rear View
    System description: RVC Compact+
    Software number: 5Q0980568A
    Software version: 0180
    Hardware number: 5Q0980568A
    Hardware version: H07
    ODX name: EV_CamSysRVRVCARPANAMQBAB
    ODX version: 006008
    Backup name: rear cam
    Long coding:
    0173000161002001000048
    Adaptations:
    Activating and deactivating all development messages:
    Not activated
    Actuator, PWM signal:
    100 %
    Brightness:
    50 %
    Control module switch-off, switch-off time:
    Control module:
    20 min
    Data bus:
    30 min
    Image contrast:
    50 %
    Wheel/tire description:
    1950 mm
    camera_off:
    35.00 km/h
    camera_on:
    30.00 km/h
    color:
    50 %
    debounce_time_for_reverse_gear:
    0 ms
    display_position:
    0 px
    engine_restart_timer:
    0 ms
    Frequency_Swinging_Logo:
    100 Hz
    FSG_control_state:
    On
    grafic_element_setting:
    setting_1_HMI_mode:
    ff
    setting_1_pallet_ID:
    255
    setting_1_color_value:
    ffff
    setting_2_HMI_mode:
    ff
    setting_2_pallet_ID:
    255
    setting_2_color_value:
    ffff
    setting_3_HMI_mode:
    ff
    setting_3_pallet_ID:
    255
    setting_3_color_value:
    ffff
    setting_4_HMI_mode:
    ff
    setting_4_pallet_ID:
    255
    setting_4_color_value:
    ffff
    setting_5_HMI_mode:
    ff
    setting_5_pallet_ID:
    255
    setting_5_color_value:
    ffff
    setting_6_HMI_mode:
    ff
    setting_6_pallet_ID:
    255
    setting_6_color_value:
    ffff
    setting_7_HMI_mode:
    ff
    setting_7_pallet_ID:
    255
    setting_7_color_value:
    ffff
    setting_8_HMI_mode:
    ff
    setting_8_pallet_ID:
    255
    setting_8_color_value:
    ffff
    setting_9_HMI_mode:
    ff
    setting_9_pallet_ID:
    255
    setting_9_color_value:
    ffff
    setting_10_HMI_mode:
    ff
    setting_10_pallet_ID:
    255
    setting_10_color_value:
    ffff
    setting_11_HMI_mode:
    ff
    setting_11_pallet_ID:
    255
    setting_11_color_value:
    ffff
    setting_12_HMI_mode:
    ff
    setting_12_pallet_ID:
    255
    setting_12_color_value:
    ffff
    setting_13_HMI_mode:
    ff
    setting_13_pallet_ID:
    255
    setting_13_color_value:
    ffff
    setting_14_HMI_mode:
    ff
    setting_14_pallet_ID:
    255
    setting_14_color_value:
    ffff
    setting_15_HMI_mode:
    ff
    setting_15_pallet_ID:
    255
    setting_15_color_value:
    ffff
    setting_16_HMI_mode:
    ff
    setting_16_pallet_ID:
    255
    setting_16_color_value:
    ffff
    setting_17_HMI_mode:
    ff
    setting_17_pallet_ID:
    255
    setting_17_color_value:
    ffff
    setting_18_HMI_mode:
    ff
    setting_18_pallet_ID:
    255
    setting_18_color_value:
    ffff
    setting_19_HMI_mode:
    ff
    setting_19_pallet_ID:
    255
    setting_19_color_value:
    fff
    image_delay_timer:
    0.0 s
    Minimal_time_to_stay_in_bus_sleep_before_ECU_off:
    20000 ms
    rv_dark_off:
    10.00 km/h
    rv_dark_on:
    15.00 km/h
    RV_Last_Mode:
    90° parking spot
    RV_Start_Mode:
    90° parking spot
    Time_to_open_Swinging_Logo:
    1200 ms
  2. #292
    Nov 2016
    MAPLETON Qld
    I installed speed sign recognition on my Tig. Worked fine for 2 weeks but now getting an error message "traffic sign recognition fault" and a non- erasable fault (U1120) in the dashboard module on my OBD11. Has anyone else experienced this? It still seems to work according to my wife, but have not checked it myself yet.
  3. #293
    Aug 2017
    Netherlands
    Tomorrow evening I will dump my Tiguan and investigate the TJA further. Also will do some changes together with a friend who has VCDS/VCP etc.
    Like Video-in-motion, DRL's at the back, disable warnings on the Navi, beep at lock/unlock, needle sweep, when using auto climate control see the speed indication stuff like that .
    We will also try to investigate and compare dumps to get a hold on the TJA thing. He thinks more coding needs to be done besides the modules13 and 44.
  4. #294
    Aug 2017
    Uk
    Quote Originally Posted by SNOBUM View Post
    Hi Jap
    Please could you post your codings & adaptation channels so I can compare. I followed these instructions on my MY17 Tiguan R-Line:
    Activate Trailer Assist - VCDSSchweiz
    I had the genuine trailer electrics installed by dealer, so car knows when trailer plugged in, but Trailer Assist never worked. After altering the above coding & adaptations, I now get a message that Trailer Assist is available and to press the Park Assist button when the car is in reverse - once I do that, a picture flashes up showing how to control via the side mirror selector/adjuster, but then an error message comes up to say take control of the steering wheel as Trailer Assist is not available due to the reversing camera being obscured.
    I have no idea why this error occurs, as the camera is clean, I have removed the jockey wheel & re-routed the trailer plug out of view in-case it is getting confused.
    I did have a problem with the final adaptation change, as Klemme 15 does not appear in the drop down list??
    Any assistance would be greatly appreciated.
    what modules do you want to see, I posted trailer and camera, but ny trailer doesn't go up to byte 11
  5. #295
    Sep 2017
    Auckland
    hi everyone. has anyone successfully tweak led indicator as DLR on MK2 tiguan highline using OBD11 ?
  6. #296
    Nov 2013
    AUS
    Quote Originally Posted by NZ_GolfR View Post
    Here is the coding to enable Rear DRL. This works on the LED Lights that come with the NZ R-Lines, not sure if it works with any other type of rear lights.
    Central Electronic (09) - Adaptation - Leuchte16BLK SLB35BLK SL KC9 - Lichtfunktion B 16 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
    Central Electronic (09) - Adaptation - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - Lichtfunktion B 17 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
    Central Electronic (09) - Adaptation - Leuchte23SL HLC10 - Lichtfunktion B 23 - Change to Tagfahrlicht (Original Value: Parklicht links (beidseitiges Parklicht aktiviert li & re))
    Central Electronic (09) - Adaptation - Leuchte24SL HRA65 - Lichtfunktion B 24 - Change to Tagfahrlicht (Original Value: Parklicht rechts)
    There is option in there to adjust the brightness as well however I haven't changed this setting as it will potentially make the park lights too bright at night time.
    Just wondering if you can point me to where the brightness settings are. Might play around with that when I get a chance.
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  7. #297
    Nov 2013
    AUS
    Just wanted to thank everyone who has contributed to this thread. I've activated the following thanks to many of you:
    - 3rd/High-Mounted Brake Light Tweaks
    - Avoid Dimming LED Lights when Indicating Golf Mk7
    - Traffic sign recognition/Dynamic Road Sign Display
    - Automatic Window Closing in Rain
    - Enable rear DRLs
    - Adjusting Cornering Fog Light Sensitivity (Speed Threshold)
    - Disable Start/Stop
    - TMC Traffic
    - Seat heating memory
    - Enable Fan Speed Indication for Airconditioning when in AUTO mode
    - Gauge/Needle sweep on AID
    - AID GTI/R adaptations
    - AID Colour change
    - Disabling screen Nag
    - LED lights in door mirrors light, even in close
    - Lock Acknowledge with Horn Golf Mk7 instructions
    - ‪Automatic Air Recirculation
    Current:
  8. #298
    Jun 2017
    North Sydney, NSW
    Quote Originally Posted by veew View Post
    Thanks for starting the thread! - it is very useful to find Tiguan MK2 compatible tweaks in one place - there is a huge amount of material across these forums and it is a bit hard to know where and what to search for.
    It seems your first post is fairly up-to-date with links - perhaps the mods can make this post 'sticky'?
    Tiguan Highline 162TSI | Indium Grey | DAP | MY18
  9. #299
    Agree - this is a great sticky candidate
  10. #300
    Jul 2014
    The Hills, Sydney
    Just a thought - the US-spec Mk2 Tiguan remote start via the keyfob - is it possible that in *theory* this is just coded into the car with no additional hardware as it starts the engine when triple pressing the unlock button? if so it may be able to be coded in to a ROW spec Tiguan? and thus coded to my Golf 7.5
    2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
