Page 22 of 118 FirstFirst ... 1220212223243272 ... LastLast
Results 211 to 220 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #211
    Aug 2017
    Netherlands
    Quote Originally Posted by veew View Post
    Had the tablet replaced for a new one. Same issue, doesn't recognise both my home normal and 5GHz wifi. Bit reluctant to buy a more expensive tablet considering it is only going to be used for the OBD2 dongle.
    Anyone else have the D-link 2900AL modem/router?
    Is the D-link using auto-channels or did you have them configured manually?
    Could be that it's using a channel that the tablet does not recognize depending on it's original region.
    Can you download a wi-fi scan app or something on the tablet?
    As it can be online using your mobile phone as a hot-spot, maybe you can have your mobile phone connect to your wi-fi at home and then share through BT the wi-fi to the tablet?
  2. #212
    Aug 2016
    Auckland, NZ
    Quote Originally Posted by GeeMoney View Post
    Asking for it right away.
    Any chance you can test with these long codings?
    I have gone through and compared the long codes between the A3, Sharp's Tig and my Tig as well. Most of the differences are explained by the different make, model, type and origin of car as well as different features like TSR and Light Assist being enabled. There are only a couple differences left that I can tell exactly what they are. At this stage not too keen to randomly enable long coding without seeing coding from a Tiguan with TJA working as it is a bit too risky copying from an A3. I also think there will be some differences in the Adaption Channels as well that will need to be compared first.
    On a side note, the hardware version (H06) is the same for them all and both the A3 and Sharp's are running same software version (0231). Mine on the other hand is running 0271, which is the same as Hugo_nz.
    Hugo_nz, any chance you can send through a copy of your backups of module A5 and 44 for me to have a look at?
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  3. #213
    Aug 2017
    Netherlands
    Quote Originally Posted by NZ_GolfR View Post
    Ok, i've asked for the adaptation channels. As soon as they come in, I will send them to you. (by personal message or through this topic?)
    I don't know anyone with a working TJA on a Tiguan, any chance there is someone on this forum?
    Otherwise I can ask my dealer if he has a Tiguan with TJA and borrow that one for a test spin . But this will take a lot of time as I don't have the tools to collect the long codings stuff so I need to arrange with other people.
  4. #214
    Aug 2016
    Auckland, NZ
    You can PM me with them if you want. Hugo_nz has got TJA on his after the dealer did an update so hoping he can send me through a copy of his scans when he can.
  5. #215
    Apr 2017
    Strange, what does it look like if you display the speed sign in the main display window of the AID?
    Would you please tell me how to do that?
    I usually just get the nav screen
  6. #216
    Apr 2017
    Quote Originally Posted by Lindsay View Post
    That is what an Australian road sign looks like. New Zealand signs do not have the white rectangular background
    Oh thanks!
    So that looks ugly to me with the white
    TSR does know australian signs huh
  7. #217
    Nov 2013
    AUS
    Will have a look before returning it. Cheers
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  8. #218
    Aug 2016
    Auckland, NZ
    My suggestion is to login to the modem and look at the wifi settings and if the channel is set to auto for the 2.4Ghz try changing it to 6 or 7. I have seen it where if the channel is set too high or low some wifi modules can't see it properly. Channel 6 or 7 is pretty safe channel that everything should be able to see.
  9. #219
    Nov 2013
    AUS
    You sir are a bloody champ, it worked! I can finally deactivate the wretched auto stop/start!
    Addit: Well that was premature, downloaded the app via the email but now the tablet can't open it. Is it because I've already downloaded it on the old tablet?
    Addit again: Looks like the Google Play store had the program I had installed last time. Came up as "Car Diagnostics Pro VAG OBD2" by Voltas IT. Hopefully this is the actual program and not some trojan. Will see tomorrow morning.
    Current:
  10. #220
    Aug 2017
    Netherlands
    Hey, I did the suggestion earlier just kiddin
