Ok, so here are few from me
All tested and working. I dropped those from NZ_GolfR to avoid duplicating.
- LED lights in door mirrors light, even in close:
Modules 42 and 52 -> Coding -> Byte 01 -> Bit 5 deactivated
- DRL off when lights switch on position "0", but on when "AUTO":
Module 09 -> Security Access enabled -> Adaptation -> search for "ENG115734" and change to inactive
- DLR option to switch on/off from menu (independent from above tweak):
Module 09 -> Security Access enabled -> Adaptation -> search for "ENG116594" and select from dropdown "Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich" -> change to active
Now you can go to Car Setup menu and you'll find extra tick to enable/disable DLRs.
- Refuel quantity on AID as one of Driving data options:
Module 17 -> Coding -> Byte 10 -> Bit 4 activated
- Fan speed indicator (leds around button) when in AUTO mode:
Module 08 -> Coding -> Byte 11 -> Bit 6 activated
- Disable "ingnition on" alarm, when drivers door open:
Module 17 -> Adaptation -> search for "ignition" and select "actuator should appear as the only entry" from list -> change to "No display"
- Changing "blink" number on comfort blinkers:
Module 09 -> Security Access -> Adaptation -> select "Turn Signal Controls-Komfortblinken Blinkzykien" -> change between 1 and 5
- Gauge/Needle sweep on AID
Module 17 -> Coding -> Byte 01 -> Bit 00 activated
- "beep" when lock and unlock car doors
Module 09 -> Security Access -> Adaptation -> search for "acknowledgement" and depending what you want, select active or inactive for available options with "Akustische" in description
