Page 14 of 118 FirstFirst ... 412131415162464114 ... LastLast
Results 131 to 140 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #131
    Jul 2016
    Quote Originally Posted by NZ_GolfR View Post
    Yes, it is permanently disabled now. The change you made tells the Stop/Start system to only kick in if the voltage level is over 12V but since other things are running in the car it will never read 12V.
    You will notice that when you go for a drive next and stop at an intersection/traffic lights it will show the A symbol with a line through it in the dash to say the Stop/Start system will not turn on. The button by the gear lever now does nothing.
    Thank you....Happy Days!!
    2017 Tiguan R Line 162TSI, DAP, White. Upgraded speakers.
  2. #132
    Jul 2017
    Auckland, NZ
    Can confirm that Traffic Sign Recognition works on my car using the coding in this thread.
  3. #133
    Jul 2016
    Quote Originally Posted by Hugo_nz View Post
    Can you please point me to that post?.... cheers!
  4. #134
    Apr 2017
    Are there any errors?
    Is it in Fusion mode or Road sign detect?
    Is the function restricted?
  5. #135
    May 2017
    Sweden
    Does traffic sign recognition works on cars WITHOUT navigation?
    Skickat från min SM-G950F via Tapatalk
  6. #136
    Apr 2017
    JHB, South Africa
    Quote Originally Posted by Brobbe View Post
    If you have module A5 on your car it will work.
    1.4 Tsi R-Line Manual (South Africa)
  7. #137
    May 2017
    Sweden
    Quote Originally Posted by cabby09 View Post
    Thank You! I must check this tomorrow!
  8. #138
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by zzc2010 View Post
    It's road set to "Detect" not "Fusion". It does give a limited function warning, but it works as expected ie., it picks up the road-side signs and also temporary signs which have been placed for road-works.
  9. #139
    Jul 2017
    Auckland, NZ
    I enabled the 360 camera feature today. Pretty neat. Check out thevideo:
    https://www.youtube.com/embed/hhwCUR1k0Wg
  10. #140
    Aug 2017
    Netherlands
    The camera should also be there already? Or did you build it in?
