Page 117 of 118 FirstFirst ... 1767107115116117118 LastLast
Results 1,161 to 1,170 of 1175
Thread: Mk2 Tiguan VCDS Tweaks
  1. #1161
    Pacific Paradise QLD
    Quote Originally Posted by The J Man View Post
    I tried the Traffic Sign recognition setting and it works - but not great.
    Turning into a side street with the 50 zone close to the intersection results in a 50% success rate reading the new speed limit. Turning left has a worse success rate.
    This has a very low wife acceptance factor, so I decided to switch it back
    Now I don't even get the speed limits from the GPS!
    To my utter dismay, VCDS did not automatically log my changes, so now I'm having to guess how to change back to "default"
    Unless of course there's a handy reference somewhere to "back out" those changes (my google-fu has not been successful thus far)
    Here you go Its for an OBDELEVEN but is the same settings and will reverse it as I have done it in the Kamiq
    https://drive.google.com/file/d/1spk...ew?usp=sharing
  2. #1162
    Apr 2012
    thanks Hillbilly
    I'll double check but I'm fairly certain I reversed all those settings already, but I'll double check using this list
    MY17 Volkswagen Tiguan 162TSI Highline, DAP, Sunroof, Caribbean Blue
    MY13 Volkswagen Golf 103TSI Highline, Night Blue
  3. #1163
    Apr 2012
    thanks Hillbilly
    Hmm I think I see the problem - I shouldn't have "undone" every setting because 5F:byte24:bit6 probably needs to stay on in order to display speed limit in the map
  4. #1164
    Feb 2023
    Sydney NSW
    Hi all, newbie here only just intro'd myself.
    I had a go with the vcds tweaks on the sticky wanted to share my experience.
    As everyone says take a full map back up of stock, I didnt do this and am regretting it as I went through a bunch of the updates and don't have a baseline to fall back on. It only takes 10min .. DO IT.
    Finally log all changes you make even if you have a baseline. Again makes life easier to go back to what it was.
    As for the acutal coding experience, pretty much as explained in the sticky. Some options in German but just used google to work out which to select.
    My car already had the Dynamic light assist, yet this dumbo just followed the sticky verbatim top down and coded in Light assist .. which is a step backwards. Insert above note and my regret above of not taking a baseline. Anyway luckily the car was smart enough to not take my stupid commands (although vcds didnt throw errors and accepted all coding) so I still have Dynamic light assist (but i havent tested it in real life, however start up dance still appears and when I checked my full map/scan codes dump they match the Dynamic light assist settings).
    The 2019 Allspace seems to have alot of stuff the shorty needed coding as standard so please check before you do as I did and try to "code" it. E.g. DLA as above, 3D camera, undertaking etc of course the other explanation is the previous owner coded it before I took the keys.
    Finally I think the only useful contribution I have is when I followed this, for the rear DRL's -
    Central Electronic (09) - Adaptation - Leuchte16BLK SLB35BLK SL KC9 - Lichtfunktion C 16 - Change to Tagfahrlicht (Original Value: nicht aktiv)
    Central Electronic (09) - Adaptation - Leuchte16BLK SLB35BLK SL KC9 - Dimmerwert CD - Change to 127 (Original value 0)
    Central Electronic (09) - Adaptation - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - Lichtfunktion C 17 - Change to Tagfahrlicht (Original Value: nicht aktiv))
    Central Electronic (09) - Adaptation - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 - Dimmerwert CD - Change to 127 (Original value 0)
    Central Electronic (09) - Adaptation - Leuchte23SL HLC10 - Lichtfunktion C 23 - Change to Tagfahrlicht (Original Value: Original Value: nicht aktiv)
    Central Electronic (09) - Adaptation - Leuchte23SL HLC10 - Dimmerwert CD - Change to 127 (Original value 0)
    Central Electronic (09) - Adaptation - Leuchte24SL HRA65 - Lichtfunktion C 24 - Change to Tagfahrlicht (Original Value: nich aktiv)
    Central Electronic (09) - Adaptation - Leuchte24SL HRA65 - Dimmerwert CD - Change to 127 (Original value 0)
    In my case I didn't have the option Tagfahrlicht as per the instructions. But had something called "Daytime running lamps" as well as "Daytime running lights" - use the LAMPS option and it worked.
    Also if your vcds is old, can use OBD Coding - Online Tool to do long coding if the helper doesnt have the bits defined.
    Hopefully that helps someone.
    Audi S4 B8 - APR Stage II
    VW Tiguan mk2 Allspace 162tsi
  5. #1165
    Feb 2023
    Sydney NSW
    Hi all,
    Firstly thanks for this topic, I had a go at the mods from the sticky and wanted to share a few notes on my vcds experience.
    As everyone says take a full map back up of stock, I didnt do this and am regretting it as i went through a bunch of the updates and dont have a baseline to fall back on. It only takes 10min .. do it.
    As for the actual coding experience, pretty much as scripted in the sticky.
    My car already had the Dynamic light assist, yet this dumbo just followed the sticky verbatim top down and coded in Light assist .. which is a step backwards. Insert above note and my regret above of not taking a baseline. Anyway luckily the car was smart enough to not take my stupid commands (although vcds didnt throw errors and accepted all coding) so I still have Dynamic light assist (but I haven't tested it in real life, however start up dance still appears and when I check my full map/scan codes they match the Dynamic light assist settings).
    The 2019 Allspace seems to have alot of stuff the shorty needed coding as standard so please check before you do as i did and try to "code" it. E.g. DLA as above, 3D camera, undertaking etc of course the other explanation is the previous owner coded it also.
    Finally I think the only useful contribution I have is when I followed this to enable rear DRL's -
    Also if your vcds is old, can use OBD Coding - Online Tool to do long coding if the helper doesn't have the bits defined.
  6. #1166
    Nov 2016
    Sydney NSW
    Trying to add the performance monitor to a MY19 Tiguan Allspace.
    I believe it needs some sort of software update to the multimedia interface before being able to activate with OBDeleven.
    Has anyone done this or have any information on the software update required?
    Thanks
    Sent from my moto g82 5G using Tapatalk
  7. #1167
    Nov 2019
    North America
    Believe you need a SWaP code for this function to fully work. I don’t believe it’s something you can turn on through coding alone.
  8. #1168
    Mar 2021
    Quote Originally Posted by csingh View Post
    Thanks
    Not sure the reason you want it, but it's useless in my opinion.
    Boost pressure is atmospheric + turbo, so it will tell you you're pushing 35psi etc. it wont tell you what a traditional mechanical boost gauge will tell you, and the "kW" will max out at the factory rating, so a 162tsi will always max out at 162kW, no matter what performance mods
    have been done. Even those with a stage 1 tune will max out at 162 even though it's pushing way over.
  9. #1169
    Aug 2023
    Queanbeyan
    Have a 2023 Tiguan, dynamic turning lights and blindspot alert not installed. Or so the dealer service tells me. Can VCDS turn these functions on? Or does there need to be more hardware installed?
    By the way I'm very new to VCDS. Used to be able to read assembler longtime ago and program hardware.
  10. #1170
    Sep 2016
    WA, Perth
    I have a monochrome 23 Tiguan which has no blind spot alert. I was told the hardware is physically missing by the dealer.
