Originally Posted by
fatjoez
Followed this instructions using VCDS & had to do headlight adjustment & clear fault codes multiple times.
I had ERROR AFS CORNERING LIGHT.
The error finally cleared. I will test if the light works at night time but for now the "auto" headlight sign is showing in my digital display when I press the light arm & also the "dynamic light assist" option is available in car settings.
Took me two goes but was my fault for not implicitly following the instructions Maybe you as well?
