Have you putt the verification code in to get into programming in the module. Ive only got a V1 and it does it
Error 31 can need the App data cleared from within the app on your phone. Presumably you are using an Android phone and not a piece of an Apple
Clear data and restart the app
MY19 Tiguan Highline R-Line
OK, cleared the data from the app (I thought you meant that this was done within the app and I could not see where).
I had to sign in to the account, but no pairing code or device password needed, it just goes straight in.
Much much quicker to connect this time.
Successfully defeated Start/Stop using voltage method. Success!
I noticed in the menu an item called "Deactivation of start-stop function", with options of
Mode not active (current setting)
Stop release
Stop prohibition, no start request
Start request
System malfunction
I just wonder if this would be an even cleaner way to do it, using the Stop prohibition option?
Anyway thanks for your help, a lesson learned re clearing the data first, which hopefully may help others.
Youve got it done so dont try something that doesnt seem to have been done by anyone I can see on several international forums
There are about 2000 different settings in a Tiguan and I wouldnt touch at least 1960 of them unless i found someone else had done it first.
It can be beneficial to look through Golf Mk7 tweaks as well as some work on the Tig Some dont like Pace car taillights as the Tig ones are different and lesser quality
I didn't try it. I used the voltage method and it worked after I cleared the app data.
It is very good advice to only use tried and proven tweaks. The OBD11 opens up access to so many parameters, many of which are basic to the vehicle's operation. Best to tread very very carefully.
Having said all that, the "Stop prohibition: no start request" tweak is in fact the identical tweak as the second start/stop tweak on the Golf Mk7 list.
In my Tiguan 2017 i had the composition media. The menu looked like the first image and it was "in a line".
I coded it somehow so the menu structure looked like the second picture, like a "grid".
I want to do it on my passat now, but I can't remember how i did.
I didn't change the headunit, it was only coded/adapted with vcds.
Does somebody know how I can do it?
Skickat från min SM-G975F via Tapatalk
has anyone tried the 'starting vibration reduction'?
Select Control Unit 03 – Brake
Adaptation
Starting Vibration Reduction
Set to Starting Vibration Reduction and Torque Limitation to ‘Deactivated’
Found it on the AutoInstruct site, but curious to hear if it makes any noticeable differences.
Says it stops the automatic braking intervention during wheel hop scenarios.
