Page 67 of 68 FirstFirst ... 175765666768 LastLast
Results 661 to 670 of 678
Thread: Mk2 Tiguan Tuning
  1. #661
    Feb 2014
    Have to agree. There's been a number of reported gearbox issues with 2017 cars which although is probably still pretty low % numbers is more than almost zero for DQ500 in gen1 Tigs.
    I have a 2017 162TSI Tig, have just done the Stage 1 APR with Stage 2 loaded. Am going to get the exhaust upgrade and DSG tune done when the QLD borders open.
    What are the gearbox issues you refer to for the 2017 car? My gearbox hasnt given me dramas since purchase luckily. Although the coolant line into the engine block broke off luckily it was repaired under warranty!
    Sent from my SM-G950F using Tapatalk
  2. #662
    Quote Originally Posted by LaNOS View Post
    There's a few people with reported leaks. And there have been a few with mechatronics units replaced.
    Feb 2014
    Ok, will the DSG tune worsen this risk?
  4. #664
    I don't think it would make any difference, however it will likely make any warranty claim more of a challenge. Not that an oil leak should be a factor, however sometimes dealerships/warranty dept can be a bit tricky to negotiate if you're tuned.
    Feb 2014
    Oh excellent, I'm out of warranty anyway! I intend on keeping this car for much longer. Finally caught onto how much money you save not changing cars every 4 years haha...
  6. #666
    Jun 2020
    Gold Coast, Queensland
    I have created a separate post as well as I couldn't find much info on here, but just in case more knowledgeable people see it here, I'll ask if anyone has any experience tuning a 140TDI?
    If so, what were your findings from it?
    What tune option did you go with?
    What benefits did you see, in power, responsiveness, and fuel consumption?
    Feb 2014
    Hey guys, I just got the Stage II down pipe and high flow cat done for the Stage II APR tune. Got the car back yesti and the yellow exhaust/engine light came on. Anyone have this similar issue?
    Sent from my SM-G973F using Tapatalk
  8. #668
    Feb 2014
    I should also add I had a TCU tune done as well on the DSG which apparently increases the pressure of the clutch packs for less slip. My D1 and R are a little jerky to start with, is this something that will go away as the DSG relearns?
  9. #669
    Feb 2018
    I didn't think APR was doing stage 2 anymore, unless you booked and paid for it months ago?
    Who tuned it? Is there a chance they didn't load the stage 2 file? I would take it back to the tuner and ask them to scan the codes to see if the engine light relates to the new DP install or not
    Sent from my SM-N975F using Tapatalk
  10. #670
    Feb 2014
    Quote Originally Posted by Grugly View Post
    Yeah i got the APR Stage II tune done before the cut off and rolled back to Stage I and then just this week had the hardware installed. This was all done at Eurotune on the Gold Coast.
