It does seem high, although you seem to be able to get a lot from this engine with minor mods.
I just calculated the kw and nm from the APR data calibrations, in my original post.
Doesn't it say min 95 on the gas cap?
Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
Actually I think that 180kw on 98 is probably about right. I'm comparing this to tuned Mk1 Tiguans and what they would output on the dyno compared to a gen2 162TSI in stock form. The stock 162 Tig is only a few kwaw down on a stage 1 Mk1 Tig.
Also 0-100 times tend to confirm that to be the case also. So I really don't trust VW's brochure 162kW figure but I have confirmed the claimed stock 0-100 for the 162TSI is pretty spot on at 6.5sec. Which doesn't stack up given that the last of the gen1's with 155kW was 7.3sec. So how can you run almost a full second quicker 0-100 with only 7 more kW?
All things point to 182kw as stock output for the 162TSI Tig. My 162TSI was running at 137kwaw on the dyno and if you factor in around 25% driveline losses for the AWD and DQ500 then the numbers all line up.
Great, thanks for the insights tigger73.
2019 VW Tiguan 162TSI R-Line + Sound & Vision Package - Tint - Roof Bars.
2019 Mazda CX9 - Tint - Roof Racks.
