Page 54 of 68 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 678
Thread: Mk2 Tiguan Tuning
  1. #531
    Dec 2018
    AU
    Yes understand wanting to keep the response of a smaller turbo for a daily driver. I am yet to see anyone get near to 200kwaw with the stock turbo. You would need to have every supporting mod done to get anywhere close to that including a good DSG tune, all turbo inlet piping and intercooler piping upgraded, upgraded intercooler, turbo muffler delete, 3" DP, intake and run it on a cool morning with race gas and a 104RON map.
    Or just drop in an IS38 and a tune.
    Is apr stage 2 just a dp and tune. They claim 250kw from that. Surely that would translate to at least 200kw at the wheels even if their figures are inflated?
  2. #532
    Quote Originally Posted by Psych101 View Post
    All the stage 2 cars that I've seen (in this thread) that have been on the dyno have got between 180-185kwaw stage 2. To be honest you'll find that the DQ500 in the Tig and AWD drivetrain take a lot more out of the car. You're realistically looking at 25-30% driveline losses.
    There was a IS38 +DP get 194kwaw and that's the highest number I've seen here to date. There's possibly some cars with higher outputs as one IS38 car is running 4.1sec 0-100's and that needs a fair bit to achieve that sort of number.
    I've always been disappointed with the dyno numbers on my previous Tiguans particularly compared to FWD cars. However put them on the road and the extra traction of AWD and the FWD cars will struggle to keep up especially in damp conditions.
    Sep 2011
    Melbourne, Victoria
    Based on MK7 R Stage 2's an IS38 Tig should see close to 230-240kw@4 wheels.
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
  4. #534
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by INASNT View Post
    Don’t forget that mk7r’s have lower compression pistons/ bigger combustion chambers to make more power.
  5. #535
    I'm only reporting on what other forum members have posted after running their cars on a dyno. Unfortunately no local APR tuned cars have run on a dyno to verify any of the claimed figures and only the one IS38 car with DP which was done by Tarmac.
    I don't think that an IS38 Tig will match a Golf R output purely from the fact that the DQ500 DSG will pull the figure down. From my experience I'd expect a "fully built" IS38 Tiguan (DP, intake, intercooler, turbo muffler delete, turbo intake elbow, DSG tune) to be putting out 210-215kwaw compared to ~230-240kwaw for a Golf R. Basic stage 2 Golf R's (DP, intake) with a newer revision turbo are generally running around the 220kwaw so I'd expect a Tiguan to be down 15-20kwaw on that so ~200kwaw.
    I'm basing these numbers off the dyno days we run over this way. Some interesting reading in this list:
    Quote Originally Posted by Hole46 View Post
    Yes pistons are different in the R for lower compression ratio, however bore/stroke is the same (1984cc). There is a bunch of other differences for the higher output EA888 in the Golf R:
    • A different alloy for the cylinder head due to higher thermal stress;
    • The exhaust valves were nitrided and had a higher Ni content;
    • The exhaust valve seat rings were upgraded for improved temperature stability and wear resistance;
    • Revised exhaust camshaft timing;
    • A larger IHI turbocharger which provided peak boost pressure of 1.2 bar (17.4 psi);
    • Unique pistons for a 9.3:1 compression ratio (compared to 9.6:1);
    • For the piston cooling jets, a higher flow rate;
    • For the high pressure injectors, a higher flow rate; and,
    • A high performance main radiator with one or two auxiliary radiators (depending on market).
    So just sticking a IS38 on a GTI/Tiguan won't necessarily make it into an R. It'll come closer but will still be limited by a number of the other small differences in the 2 engines.
    Sep 2011
    Melbourne, Victoria
    Melboure_Tig could run hes APR IS38 on the same dyno as I ran my stage 2 for a direct comparison
  8. #538
    Dec 2018
    AU
    Will an APR dealer give you a stage 2 tune running a third party dp? Can't imagine this would make much difference to warrant a custom tune
  9. #539
    Yes they'll do it but it'll be the same file regardless. It's more of an issue when it comes to air intakes as these can be a bit more varied. Because they're just flashing a generic file if your intake flows more or less than the one that they used for generating the file then there can be some issues. The good thing is that the APR intake flows pretty much the same as the stock airbox with the snow-grate mod. So this is a low cost route that will give you decent compatibility.
    May 2018
    I'm coming up on 15,000km's and am planning on a stage 1 tune following completion of the first service.
    Have been told APR retail is $1299, i've heard of 10% off promotions. Are the tuners negotiable on price, there are no promotions on at the moment.
    I think i've settled on using APR as i'll only go with a stage 1 and do not plan to make any physical modifications to the vehicle.
    If at some stage i want to go back to stock is this something i can get done easily or am i up for another $1300 clams?
